RustyFender
I'm repainting MIM strat copy and have put on 5 coats of Duplicolor sandable primer, then 5 coats of Duplicolor laquer,then 10 coats of Duplicolor clear coat. How long should it take for all this to cure so I can start sanding and polishing and put it back together. It is in a room where the temp stays between 67-70 degrees F. Somebody said somewhere on a forum that if you can smell the fumes from the clear coat it is not ready. Is that true or just an oppinion?
