Wide Range Humbuckers vs Atomic Humbuckers
Discussion in 'Pickup Joint' started by Sonarman, Feb 25, 2021.
  1. Sonarman
    Sonarman Squier-Meister
    132
    Jun 6, 2020
    New England
    Marketing? Actual difference? I’m leaning towards a Classic Vibe Telecaster Deluxe, but if I can get the same electronics out of a Tornado I’ll just get the latter. And let’s be honest, buy the Deluxe anyways. But, are they actually different pickups? Has anyone come across any measurements of the two?
    Taurus and Kenneth Mountain like this.
  2. GunnyPlaysLoud
    GunnyPlaysLoud Squier-Meister
    198
    Mar 13, 2020
    Wisconsin
    I don’t have any hands on experience with the Squier Atomic humbuckers, I have a Toronado with the original Fender Atomic’s though and they are much hotter than any WRH I’ve come across. I believe the bridge humbucker is around 16k on my Fender Toronado, pretty high output for passives.
    Kenneth Mountain and Sonarman like this.
  3. radiotech
    Freedonia
    Atomics are regular sized pups, Wide ranges are larger, and have a four screw mount, to level them better.
    Kenneth Mountain and drewcp like this.
  4. Sonarman
    132
    Jun 6, 2020
    New England
    That’s what I’m finding on the web for the Atomic (16k). That’s too hot for me. I’m thinking I’ll spend the extra $50 or so and get the deluxe.
  5. Davis Sharp
    Davis Sharp Dr. Squier ‎‎‎‎‏‏‎ ‎
    The WHRB is not at all hot. Output is similar to a single coil.
  6. hrstrat57
    hrstrat57 Squier-Meister
    163
    Aug 18, 2020
    Rhode Island
    WRHB is a hot topic on sister site TDPRI
    It's a interesting read...maybe dozens of thread.
  7. Benlostforyears
    Benlostforyears Squier-Meister
    409
    Aug 17, 2020
    Western NC
    I can't speak to the new ones on the CV but I have a VM Tele Deluxe with the "Fender" stamp on the covers. They are basically just a regular vintage output AlNiCo 5 humbucker and not as hot as the Atomics. Not a real wide range CuNiFe...but those are $200 a set. Here is a pic from another thread from 2018.
  8. Toddcaster64
    Toddcaster64 Squier-holic Gold Supporting Member
    Apr 1, 2013
    Ventura
    Depends on whether your referring to the original WRHBs or the re-issues which were WRHBs in name only.
    Original WRHBs were large pickups with CuNiFe magnets. In most instances they were also run through 1000k pots. Insanely good. The re-issues were standard size and rather mediocre at that HBs put in the large case but bearing no similarities at all to the real thing.
    Having played my friends original 1975 Tele Deluxe, I had to have the real deal and I shelled out big big bucks. To me it was worth every penny.
  9. Sonarman
    132
    Jun 6, 2020
    New England
    Gotcha. This helps. I’m not considering the Paranormal Toronado anymore. Hearing what you have said here, not sure I’m going to pull the trigger on the CV deluxe. Might look for a cheaper tele body routed for HH and upgrade electronics.
  10. Hal Nico
    Hal Nico Squier-Meister
    244
    Dec 21, 2020
    If you don't mind spending some," Pocket-Change" checkout my Fleor Humbucker thread,
    https://www.squier-talk.com/threads...at-resistor-modification.183918/#post-1039015
    Contains some sound clips :)
