VM Surf Stratocaster PG
Discussion in 'Squier Vintage Modified models' started by macoshark, Sep 4, 2020.
  1. macoshark
    macoshark Squier Talker
    26
    Jan 10, 2020
    southwest
    Hows it?- I'm looking for info from anyone who switched Pickguards on their Surf Strart. Just wondering how those lipstick PUs fit into a regular SSS Fender PG? thanks
    JurnyWannaBe and dbrian66 like this.
  2. Guitarmageddon
    Windsor, Ontario, Canada
    It will fit, but will have slight gaps all around the lipsticks - they are a bit smaller than a regular Strat pickup at normal heights......less than half the actual lipstick casing comes up through the pickguard usually......I changed mine and I noticed a gap.....
    answered you on Strat-talk too
  3. macoshark
    26
    Jan 10, 2020
    southwest
    thanks GM. Do you know if those lipstick PUs show a gap when lowered down close to the PG? The seller's pics show a bit of a gap on mine.
  4. Guitarmageddon
    Yes, I set them a bit higher than I had normal Strat pickups, there's an alnico V bar magnet inside them, which has less Gauss /magnetic pull than a normal single coil with 5 alnico V pole pieces....
    macoshark and dbrian66 like this.
  5. dbrian66
    dbrian66 Dr. Squier
    Just put the whole pickguard in the new guitar! This is a Deluxe Surf pickguard in an SE guitar. Everything worked out just fine!
    PangPang, drewcp, macoshark and 2 others like this.
  6. macoshark
    26
    Jan 10, 2020
    southwest
    Nice job on your Shell Pink. I'm inquiring here for the VM Surfcaster I just bought. I probably won't switch out PGs but I'm just wondering what's involved if I go that route. tanks for posting
  7. PangPang
    PangPang Squier Talker
    48
    Jul 17, 2020
    Macau
    Beautiful pink lady!!! ;-)))
