Tele Neck Swap
Discussion in 'Squier Telecasters' started by Skip D, Jul 10, 2020.
  1. Skip D
    Skip D Squier Talker
    20
    Aug 31, 2015
    St. Marys, Ga.
    I have a Squier Classic Vibe 60's Telecaster Thinline.. I love it!! I play it about 6-8 hrs a week... Because of fret wear/height,, I feel I will need a neck replacement in the near future... I just ordered a new Squier Classic Vibe 60's Telecaster Neck with Tuners for $159..... Should it be a direct replacement?? Thanks to all in advance.
  2. IronSchef
    IronSchef Dr. Squier
    Jun 18, 2012
    Flew here on my Dragonfly
    Yes, it should fit just fine. W any neck there is always a chance you may have to fill the hole and redrill - but usually they line up just fine
    probably have mated 20-25 various necks w various bodies - have not once had to fill and redrill
  3. Eddie
    Eddie Squier-Axpert
    I did my first fill and re-drill. After clamping the neck and body in place, and re-drilling ... I found I was off by a tiny hair. Argh !!! Not the end of the world ... but I need to be more careful of any slippage during clamping. It was good practice for me to overcome my drillaphobia.
  4. Skip D
    20
    Aug 31, 2015
    St. Marys, Ga.
    CV60.jpg Thanks... It may be a few months before I need to swap it,,, but I think the hardest part is done.. That is I found an identical neck for a good price..
    drewcp, Rat cam 68, daan and 3 others like this.
  5. DougMen
    DougMen Squier-holic
    It can't be identical, 'cause if you ordered a CV 60s one, then it has an IL board, not maple.
  6. fattboyzz
  7. DougMen
  8. Guitarmageddon
    North Pole
    It's not - one is a pale hardly tinted China Grand Reward 2011-2018 neck.....
    The one he ordered is brand new production, tinted neck with different size frets and Indonesian made....
  9. LAPlayer
    LAPlayer Squier Talker
    97
    Jul 9, 2020
    LA / Denver
    Actually, you don't need a neck replacement. You only need to re-fret the effected frets.
    Skip D likes this.
  10. Skip D
    20
    Aug 31, 2015
    St. Marys, Ga.
    Description: Official Fender Squier Classic Vibe 60s Telecaster Thinline Neck- Maple- "C" Shape, 21 Narrow Tall Frets- 9.5" Radius (241 mm)- 25.5" Scale Length (648 mm)- 1.650" Width at Nut (42 mm)- Genuine Fender for a: https://www.guitarcenter.com/Squier...tegory_page.rr1|PersonalizedClickCPInCategory
  11. Skip D
    20
    Aug 31, 2015
    St. Marys, Ga.
    My plan is to refret the neck at my leisure after it is changed out.. Then I'll have a "full up neck with tuners ready to roll..
    newscaster likes this.
  12. Skip D
    20
    Aug 31, 2015
    St. Marys, Ga.
    The reason I asked is because I have never changed out a neck before..... I was curious about "standard specifications" within a model series... So,,, if I got supposedly an identical neck,, with the holes drilled for neck to body joint,,,,,,,,, could I expect it to be a easy changeout?
  13. DougMen
    It should be fine. People even put Fender necks on Squier bodies all the time and everything lines up perfectly.
    Skip D likes this.
  14. SoundDesign
    When you're ready, give some thought to stainless steel.
  15. Skip D
    20
    Aug 31, 2015
    St. Marys, Ga.
    Absolutely..... I'm already planning on it.... Still debating on doing it myself though......
  16. PapaShark
    PapaShark Squier Talker
    20
    Apr 25, 2020
    Long Island
    Have you ever had issues with neck height or neck angle ?
  17. IronSchef
    Jun 18, 2012
    Yes, I had a neck pocket that was cut too deep, but I was able to correct it w/ a shim
    Skip D likes this.
