Stagemaster 7 Covidia (BarryFlat) Baritone Conversion - F/Bb
Discussion in 'Heavy Metal Thunder' started by aoresteen, May 21, 2021.
  1. aoresteen
    aoresteen Squier-Nut
    850
    Oct 31, 2011
    Newnan, GA
    Last October I bought a Squier Stagemaster 7 hardtail out of a local pawnshop.
    https://www.squier-talk.com/threads/ngd-squier-2000-stagemaster-7ht-v2-7-in-blue-number-5.176326/
    I was cruising through You Tube and ran across this:
    I decided to stretch the neck to 28" and make a baritone out of her. I contacted the luthier in South Africa - Hayward Guitars ie Graeme Hayward and ordered the 28.0" 25 fret Stagemaster baritone neck. Yep, 25 frets!!!
    https://www.facebook.com/HaywardCustomGuitars/
    Graeme does fantastic work. COVID delayed the shipping for quite some time but it was well worth the wait. Shipping from South Africa is reasonable and I would not hesitate to order another neck from Graeme
    I put the neck on the blue Covidia body and then had to wait again. DiMarzio wasn't shipping the DiMarzio pickups I wanted (Titan 7 bridge and PAF 7 neck in creme). COVID. Well, they finally came in so I could finish the guitar.
    https://www.dimarzio.com/pickups/7-string/titan-7-bridge
    https://www.dimarzio.com/pickups/7-string/paf-7
    A "normal" baritone 6 string has the lowest string tuned to B. If it were a 7 string the lowest string would be F#. I decided to tune down a 1/2 step so that makes the lowest string a F and the 6th string a Bb or F/Bb - "Drop F". That is low - it's in bass country.
    I use 0.014-0.080 strings:
    1 Bb 0.014
    2 F 0.018
    3 Db 0.026
    4 Ab 0.036
    5 Eb 0.049
    6 Bb 0.064
    7 F 0.080
    The DiMarzio pickups really do a great job with this neck.
    Body:
    I need to sand off the Jimi decal and try a newer one. Not sure why this one turned milky when hit by the lacquer.
    Rather than use the original Squier tuners, I used a set of Gotohs. Brown's Guitar Mill in Newnan is making a double cut body for the original 25.5" neck, TOM bridge, string thru set up. Should be fun!
    I re-named this guitar "Barry-Flat". It is a gas to play.
    grizzlewulf likes this.
  2. grizzlewulf
    grizzlewulf Squier-holic
    Dec 11, 2020
    Lucerne, California
    Wowee. Put up some demos if you're able? I'm curious how it sounds
  3. aoresteen
    850
    Oct 31, 2011
    Newnan, GA
    My studio is dead right now for re-cableing. When I can I will.
