Pink Squier Stratocaster identification
Discussion in 'Squier Stratocasters' started by PatrickTeaneck, Jul 31, 2020.
  1. PatrickTeaneck
    PatrickTeaneck Squier Talker
    58
    Jun 15, 2020
    New Jersey
    Hey team!
    I'm on vacation and saw a square pop up on the local craigslist. It's pink, so I immediately thought it was a mini. It's obviously not, it's a full size, but it's not an affinity because of the headstock and it's just got a plain white pick guard, so I'm assuming it's not one of the high-end models. I'm attaching a photo of that guitar along with the other one the guy is selling, an affinity telecaster which needs some new hardware. Can anyone identify which squire this is just by a picture of the front?
    Rat cam 68 likes this.
  2. MrYeats
    MrYeats Squier-holic
    Dec 28, 2017
    South Texas Coast
    It is called Pink...The main slang term is Strawberry Shake.
  3. PatrickTeaneck
    58
    Jun 15, 2020
    New Jersey
    Cool. Any idea about what the model might be? I don't think it's a bullet, or an affinity because of the headstock. I don't think it's a vintage modified or a classic vibe because of the plain white pickguard. Is it an SE or something different?
  4. Guitarmageddon
    Windsor, Ontario, Canada
    It IS a Bullet.......Bullet Strat in pink, lowest end Squier, basswood thinner body.....decent guitars but usually used only 50-75 bucks max.....it's made in China, can tell by lack of truss rod hole plastic sleeve....
    StratVegas likes this.
  5. PatrickTeaneck
    58
    Jun 15, 2020
    New Jersey
    Is this different than shell pink?
  6. Guitarmageddon
    Yes, very different - shell pink is pale, this is very very hot pink.....
  7. John L Rose
    John L Rose Squier-holic
    Here's a stock photo of a Pink Squier Bullet Strat like the one I had.
    It says "Squier Bullet Strat" and "Fender" on the headstock. I think the one in the OP photo has that too, but it's faint.
    And "Shell Pink" is more like a Coral Pink, slightly orange.
  8. PatrickTeaneck
    58
    Jun 15, 2020
    New Jersey
    So directly under the squire label is where it says bullet? I thought that said Fender. So it says bullet on the headstock closer to the end of the headstock? I could barely see that, I just thought it was dirt! Thanks. I talked the guy down to $120 for both guitars. The Affinity telecaster needs a new bridge / saddle and volume and tone knobs. On the fence about it.
  9. Guitarmageddon
    Yep, after where it says SQUIER, in small lettering it says BULLET STRAT
    I couldn't READ that in your photos, but I am familiar with the model and can spot it from far away - it's the only 1 ply pickguard, hot pink, small headstock, trapezoid 8mm tuner shaft, 2 string tree Squier made....
    MrYeats and PatrickTeaneck like this.
  10. John L Rose
    IMHO, the Bullet Strat is certainly worth half of the $120, for an entry-level guitar. It may just need heavier strings (.011s?) and a decent setup.
    When I took mine back to the store I bought it from (a year or two earlier) for a trade-in, the guy checking it out played it through an amp for a bit, then looked up and said "Sweet!"
  11. MrYeats
    Dec 28, 2017
    South Texas Coast
    Here is one that I had and modded it:
    Rat cam 68 and Amelia like this.
  12. archetype
    archetype Squier-holic
    Righto. 570 Pink vs. 556 Shell Pink. I've seen 570 vary in intensity by who made it and what year.
    PatrickTeaneck and johnnywizzo like this.
  13. Davis Sharp
    Davis Sharp Dr. Squier
    Good vacation then. Congrats.
