One neck screw won't tighten...
Discussion in 'Tech-Talk' started by Fredline, Jan 16, 2021.
  1. Birddog144
    Birddog144 Squier-holic Double Platinum Member
    Apr 24, 2015
    South Oceanside, CA
    That's the easiest way to fix it, and as others have said, we've done it countless times. Works great.
    If it's my guitar, I'd put steel threaded inserts in it (not the cheap Home Depot zinc ones) and attach the neck with stainless steel machine screws.
  2. Angry Possum
    Angry Possum A Psychotic 6 String Collector Gold Supporting Member
    Oct 30, 2019
    Squier Town NY
    I'd try the toothpick firstly, I personally have used the ends of an incense stick on a few stripped screws, and it works great. I like Eddie's idea too, interesting, who would of thought of solder.
    Shine, Eddie and Fredline like this.
  3. Eddie
    Eddie Squirt Startocaster Infinity Gold Supporting Member
    Any news on the repair?
    Fredline likes this.
  4. Fredline
    Fredline Squier-Meister
    418
    Dec 14, 2020
    Seattle, WA
    Sadly no...I was at the gf's this weekend and the guitar was at my place...she has toothpicks & I do not, lol!
    Would it be ok to use "Thin CA" instead of wood glue?
  5. Uncle Joe
    Uncle Joe Squier-holic
    Dec 18, 2015
    Jersey
    I would try Eddie's idea if the toothpick thing hadn't worked for me so many times. Not only on guitars either. I've used more than one toothpick when the hole is big like the neck one. Personally I like to use quality wood glue, but they're all some type of acrylic adhesive.
  6. John Hurtt
    John Hurtt Squier Talker
    80
    Dec 16, 2020
    Northern California
    Elmers glue or Elmers wood glue is your friend.
  7. Eddie
    One bottle of Elmer's wood glue has lasted me 2 years already and I've barely used 1/10th of it yet.
    Fredline and John Hurtt like this.
  8. Fredline
    418
    Dec 14, 2020
    Seattle, WA
    Update: It worked! The solder trick that is. Thanks again @Eddie and to all who had suggestions.
    I'm sure I'll use them on future guitars, but hope I won't have to :)
    Angry Possum, Shine and Eddie like this.
  9. LzeroKI
    LzeroKI Squier-Meister
    253
    Jan 13, 2014
    North Carolina
    Fwiw, the wood glue/tooth pick fix works great too. I've used it on a stripped hole for a bass bridge (lots of tension pulling up on that bridge plate!) and it's held fine for months and months and months.
    Angry Possum and Byron0420 like this.
  10. Eddie
    Solder is a less invasive approach. It'll grab without deforming the wood.
    Glad it worked out. :)
    I use solder whenever I need the screw to grab better ... mostly with pickguard screws.
    Shine and Fredline like this.
  11. Byron0420
    Byron0420 Squier Talker
    29
    Dec 13, 2020
    Palm Beach
    Done it many times!!
    John Hurtt and Fredline like this.
  12. Byron0420
    29
    Dec 13, 2020
    Palm Beach
    I cleaned and saved wood popsicle sticks. Carve or cut them for lots of things like loose wood screws. Sometimes you don't even need glue. Just a shaving.
    drewcp, Angry Possum and Fredline like this.
  13. TVvoodoo
    TVvoodoo Squier Talker
    55
    May 26, 2020
    Sasquatchewan
    I've heard of a similar trick with a 1" piece of used low E or A strings
    drewcp, Fredline and Angry Possum like this.
  14. Angry Possum
    Oct 30, 2019
    Squier Town NY
    I could actually go for a popsicle right now, cherry or perhaps lemon. :p
    drewcp and Fredline like this.
  15. 66musicmaster
    66musicmaster Squier-Meister
    494
    Mount Airy, NC
    Find OUTSHINE at your local grocer. BEST popsicles known to man. At least this one.
