Intonation Question
Discussion in 'Tech-Talk' started by Lincoln518, Apr 8, 2021 at 11:18 AM.
  1. Lincoln518
    Lincoln518 Squier Talker
    15
    Jan 21, 2021
    Albany, NY
    So I just intonated my stratocaster and this picture is what my saddles ended up looking like. Is it normal to have them dialed back this far too the bridge or is this something I should be concerned about? The neck is straight with a slight bit of relief on the first few frets. Thanks in advance for the advice. 20210408_111109.jpg
    JurnyWannaBe likes this.
  2. Ace38
    Ace38 Squier-holic
    Jul 19, 2016
    Tulsa, OK.
    New strings? Pickup height properly adjusted? Neck relief and string height properly set? I don't think its anything to worry about but you might double check all that and be sure.
  3. Lincoln518
    15
    Jan 21, 2021
    Albany, NY
    My pickups are set low and the string height is as low as can be without fret buzz. Strings are about 2 weeks old.
  4. mofojar
    mofojar Squier-holic
    May 9, 2019
    Calgary, Alberta
    I usually end up having to use smaller springs or cut the springs in half for the saddles on the low E and G strings on a Strat. I'd say most of my Strats have those two strings as far back as the ones in your picture.
    radiotech, JurnyWannaBe and drewcp like this.
  5. Bob the builder
    Bob the builder Squier-Nut
    731
    Feb 25, 2017
    Rhode Island USA
    1st thing that hit me.
    Slight relief on the first few frets....
    Huh?
    If you press the 3rd fret you shouldn't have more than a red c hair at the first & 2nd.
    If you capo the 1st & press on 17 or 18 fret how much relief is there at 7th- 9th.
  6. Ace38
    Ace38 Squier-holic
    Jul 19, 2016
    Tulsa, OK.
    Yup...what Bob said. Capo at first and then see how much relief there is. If you don't have feeler gauges use a business card. If thats good then press on the low E at the last fret and see if you have 2mm gap between the string and the top of the pole, repeat on the high E and look for 1.5mm. Make sure string height is about 4/64". Some of this stuff a lot of folks "do by feel" but when asking a question like this we need numbers, not your "feel".
  7. LutherBurger
    None of mine are that far back, but don't sweat it. If it sounds and feels good, it is good.
    In my experience, intonation goes off as strings age, so don't be surprised if you need to adjust it again when you install a new set. I only set intonation when strings are new, and I change the strings when they don't sound right anymore, or if I break one.
    JurnyWannaBe and Hal Nico like this.
  8. Triple Jim
    Triple Jim Guy Who Likes to Play Guitar Silver Supporting Member
    If you press the third fret you won't have any string clearance at the second fret. :)
  9. fuelish
    fuelish Squier-holic
    I only see "saddle position" as a problem if the guitar cannot be intonated. If it's intonated properly, don't worry about it. Nobody but you is gonna look at your bridge/saddles
  10. BarnyardShark1979
    BarnyardShark1979 Squier-Meister
    275
    Jul 9, 2020
    Baltimore Maryland
    When I've upped the string gauge on some of my guitars I've had to crank the saddles way back to intonate properly. Some to the point where I had to remove a section of the spring that goes around the adjustment screw.
    On my Mustang I ended up swapping in a new bridge because the stock one had the adjustment screws pressing into the strings:
    Before
    After
  11. Hal Nico
    Hal Nico Squier-Meister
    226
    Dec 21, 2020
    If they have intoned correctly don't worry about it. There are variations on all guitars and strings/frets etc.
    As they say, "If it works, don't fix it " :D
    JurnyWannaBe, Lincoln518 and drewcp like this.
  12. Lincoln518
    15
    Jan 21, 2021
    Albany, NY
    It is intonated perfectly and sounds great. I just want sure if it was an indication that something was wrong with my neck.
    LutherBurger likes this.
  13. radiotech
    Freedonia
    Like any mechanical adjustment, it’s good to have it in the middle of the span so you can adjust it more if you need to, but you still have some adjustment left. Any more, and I’d suggest shimming the neck back slightly to get those closer to the middle (that’s also what micro-tilt necks are for).
    My ‘51 is about like that.
  14. LutherBurger
    Nah.
    Are those Graph Tech saddles?
    Lincoln518 likes this.
  15. Lincoln518
    15
    Jan 21, 2021
    Albany, NY
  16. DougMen
    DougMen Dr. Squier
    A micro-tilt ONLY affects the neck angle, and the height of the neck in the neck pocket, and has no effect on the length of the neck in relation to the bridge, and so has no effect on the intonation in any way. That's absurd!
  17. radiotech
    Freedonia
    Tilt the neck back so the headstock is further away from the bridge will absolutely effect intonation...
    ...or you are really bad at sarcasm...
