Help me understand....
Discussion in 'Pickup Joint' started by jamesgpobog, May 4, 2021.
  1. jamesgpobog
    jamesgpobog Squier-holic
    Feb 18, 2020
    SoCal
    Elactronics ain't my strong suit. I sort of understand 'humbucking' to cancel noise, but what is the difference between coils wound cw/ccw, and 2 coils wound same direction, but one with leads reversed?
    Eddd likes this.
  2. corn
    corn Squier-holic
    Feb 27, 2013
    San Diego
    I’m not very savvy on electronica crap either, but my understanding is if the leads are reversed then that is usually a middle pickup?
    Eddd likes this.
  3. LutherBurger
  4. howserx
    howserx Squier-Nut
    500
    Apr 20, 2017
    Toronto, Canada
    Ya know, after reading this I'm suspicious of how I put my strat together... I would bet money that I goofed somewhere along the line when rewiring my pickguard...
    Amelia likes this.
  5. LutherBurger
    Simple starting point: point a compass at each pickup. The one whose polarity is opposite the other two belongs in the middle.
    Shine, GunnyPlaysLoud and Amelia like this.
  6. jamesgpobog
    Feb 18, 2020
    SoCal
    Actually, I should have clarified the context. I'm thinking of 2 P-90's and a 3-way switch (build I'm working on now).
    My recent Tele build (the redwood) has a Tele bridge pup and a GM alnico 2 'smooth velvet' single coil (not tele) at the neck.
    I looked at the links, mostly Greek, but one thing caught my attention, position 2 (both pups) is in fact thin and weak. Wondering if the next with 2 p90's can be hum cancelling in position 2/
    Still don't have a clue
  7. IronSchef
    IronSchef Dr. Squier Double Platinum Member
    Jun 18, 2012
    Flew here on my Dragonfly
    Yep - p90s are single coils — if they are RWRP to each other , then hum cancelling
  8. jamesgpobog
    Feb 18, 2020
    SoCal
    Are P90 sets usually sold that way?
  9. IronSchef
    Jun 18, 2012
    I know tonerider Seymour Duncan and Lollar sell RWRP P90 sets
  10. howserx
    howserx Squier-Nut
    500
    Apr 20, 2017
    Toronto, Canada
    Well, not a compass or decent magnet in the house to be found. I did find one that let me tell that the first two pickups (neck and middle) are oriented the same direction. As soon as I get a decent compass I'm, gonna rip poor frank apart and get it done right. (the tone pots are reversed as well) . I'm Stoked! My strat will finally sound straty!
    I love this stuff!
    LutherBurger likes this.
  11. jamesgpobog
    Feb 18, 2020
    SoCal
    OK, I got a magnet and checked out the pups. Remember, this is a 2 pup tele, not a 3 pup strat.
    If the magnet attracts to the bridge pup, it repels at the neck. Bridge is an import (not sure of mfg) regular tele. Neck is GM single coil (not tele style) 'smooth velvet' alnico 2, listed as a neck pup. Switch position 2 (both pups) seems thin. Is there a fix for this?
    There is a listing for a strat middle pup alnico 2, RWRP. Is that the fix?
  12. LutherBurger
    Good. The pickups are opposite polarity. We're halfway there...
    Is that a Strat pickup? If it is, this is gonna be easy....
    Yep. Reverse the neck pickup's two leads.
  13. jamesgpobog
    Feb 18, 2020
    SoCal
    Yep, a strat pup. So I just swap signal and ground?
  14. spanker63
    spanker63 Squier-holic
    Nov 16, 2010
    Upstate NY
    Yup, when two pups are on and they sound weak together, they are out of phase. Swap those two wires and you should be good to go.
    jamesgpobog likes this.
  15. LutherBurger
    Yeah. If what you're hearing is two pickups out of phase (thin, weak, and weird) and not the typical Tele middle position sound (sweet and chime-like), swapping those wires will correct it.
  16. jamesgpobog
    Feb 18, 2020
    SoCal
    Will position 2 be hum cancelling?
  17. spanker63
    Nov 16, 2010
    Upstate NY
    I believe that depends on how the pups are wound.
  18. LutherBurger
    If it isn't now, it will be when you reverse the leads because your magnets are opposite polarity.
  19. jamesgpobog
    Feb 18, 2020
    SoCal
    Cool. One thing I do is shield like crazyI wrap the pup leads with copper tape and have toyed with the idea of using small copper tubing in a wire race.
