Shine
Just ran across this video. Seems especially pertinent to this thread.
Your suggestion of trying different strings seem very solid .Those with far more experience, especially with Strats than I, have given you many good suggestions about getting closer to a 60's era Strat tone.
You mentioned the sparkle and chimmey sound for a Strat. One thing is lowering the pickups so low will tend to emphasize the mids and lower tones. If you are looking for shimmer and sparkle, you would need to raise the pickups considerably. You also possibly might explore for a different brand of strings. Something akin to what was available in the 60's.
Outside of possibly the cost of strings (I'd ask Strat players for brand/size suggestions), adjusting pickup heights is free. Just time consuming if done in small increments looking for the 'sweet spot'.
Good luck.
What a moron that guy is. That sounds terrible putting the chorus and the delay before the overdrive, because it's distorting the chorus and delay. The correct order for an effects chain should be compressor first, then overdrive or distortion, then modulation, then delay, and finally reverb last. Everything will sound much better that way, unless you want your chorus, delay and reverb horribly distorted. Jeez Louise!Here is a little guide to fx pedals which might be useful (although he doesn't mention reverb which is imho really important). It starts around 2:18 :
I took a VM, set it up like a ‘50s Strat. TexMex pups, ‘50s 7.25 Vintage Fender MIM Maple neck.Bought a VM Modified 70's Strat (Rosewood finger board) in 2015.
Didn't like the Duncan-Designed SC-101's . They were too hot.
Swapped them out for Bare Knuckle Irish Tours.
Maybe made a mistake?
The Irish Tours are not as hot as the SC-101's but are still hot-ish. Neck and Middle are around 6.4 DC output and bridge is around 7.4
I've lowered them quite some way so they are more or less flush with the pick guard...or just a tad above it.
But they just don't sound very "Stratty" to me.
I know the VM 70's Strat body is Basswood.
I've read that Basswood can be warmer and more mids-heavy than Alder - and that perhaps could be part of the issue in combination with the pickup choice I have made.
Has anyone on this forum swapped out the Duncan-Designed SC-101's on a VM Vintage Modified Strat for lower output pickups (maybe between 5.7 DC output and nothing higher than 6.2) and got good "Stratty" tones out of it? OR is it always going to be a challenge to get a decent Stratty tone out of a BUDGET basswood bodied guitar.....and I'd be better off with an Alder-bodied Strat???
