Conversion bushing is too small — DIY solution?
Discussion in 'Tech-Talk' started by campermoose, Oct 15, 2020.
  1. campermoose
    campermoose Squier-Meister
    120
    Apr 22, 2020
    Trying to upgrade to vintage style Gotoh tuners, but the tuner holes are a bit too large for 3/8" conversion
    and too small for 10.2 / 10.5 mm bushings.
    Is using masking tape or other material to enlarge bushings frowned upon / has serious downsides? Foil? Thin sheet metal?
    Rather not mess with the headstock itself, but tired of buying and returning wrong bushings.
    Thank you!
  2. beagle
    beagle Squier-Nut
    907
    Nov 19, 2017
    Yorkshire
    I've used tape, foil, paper, whatever. It's not permanent, hurts nothing and once the ferrules are pressed home only you know what you did. ;)
    Mr_10awg, Davis Sharp, corn and 4 others like this.
  3. Guitarmageddon
    Windsor, Ontario, Canada
    It would probably be better to use a wood reamer tool and SLOWLY remove a bit of wood from the front, very carefully, so the large bushings are able to press in.....
  4. beagle
    beagle Squier-Nut
    907
    Nov 19, 2017
    Yorkshire
    I'd go with the paper/tape. Less chance of screwing up and the neck remains stock. Tapered reamers aren't the right tool for the job and the holes are too big anyway, not too small.
  5. Guitarmageddon
    Yeah I thought he said it was too small for 3/8" oops.....
  6. beagle
    beagle Squier-Nut
    907
    Nov 19, 2017
    Yorkshire
    It's mixing metric and imperial, but I'm used to it after over 50 years of doing it myself.
  7. campermoose
    120
    Apr 22, 2020
    Thank you for recommendations!
    Lol, yeah, the sizes are all over the place, and once the bushings are bigger than 3/8" the markings switch to Metric (which I prefer anyway). Guess writing 13/32" (10.2mm) throws people off completely :D
    Metric just makes so much more sense :)
    Kenneth Mountain and beagle like this.
  8. Michael7
    Michael7 Dr. Squier Gold Supporting Member
    You may be able to cut 3/8" wide metal shims out of a beer can and coil them around a socket or dowel to get a bit of curl in them. Just not sure how that aluminum is. Can probably cut it with a utility knife.
    Kenneth Mountain and campermoose like this.
  9. gary mitchell
    gary mitchell Squier-Nut
    849
    Aug 23, 2019
  10. Michael7
    I meant to say that I didn't know how thick the aluminum is, but I measured a pop top and that was .010". That means a shim from a can would reduce the hole diameter by .020", which is just over half of a millimeter. In case this info is needed at a later date.
  11. DrBeGood
    Done that once and it works great.
    Mr_10awg, drewcp, campermoose and 2 others like this.
  12. Jay Jackson
    Jay Jackson Squier-Nut
    959
    Sep 1, 2018
    sanluisobispo CA (3401
    I wonder if you can get some heat shrink to fit over the bushing and increase the Outer diameter that way.
  13. Uncle Joe
    Uncle Joe Squier-holic
    Dec 18, 2015
    Jersey
    Plumber's tape.
    Wizzer, drewcp and campermoose like this.
  14. campermoose
    120
    Apr 22, 2020
    Thank you again!
    I reordered the bushings from Stew Mac, these were the closest match, will try the beer can first — seems like having softer materials light plumber's tape and shrink wrap might be a problem due to pressure.
  15. Tamarindo03
    Tamarindo03 Squier-Nut
    507
    Mar 18, 2017
    Lucerne
    I made my own conversion bushings out of an aluminum tube so that I can use the original vintage style bushings.
    3FA1F4E3-441C-4C09-B559-364D4E00E16F.jpeg 9722D400-B785-4D47-8DC3-ACA728644135.jpeg 6D477B24-5A1C-47FD-AB4F-953EACA3135D.jpeg 29BA2153-ECD4-4DED-80B2-447B3A6146F1.jpeg
    campermoose and drewcp like this.
  16. surf green
    DSCN4358-001.JPG I've used chrome screw trim rings on older guitars when the factory bushings are missing. No mods, drop 'em over the stem and the wound strings hold them down tight. Available at any hardware dept.
    beagle, campermoose and drewcp like this.
  17. campermoose
    120
    Apr 22, 2020
    Looks exactly like my situation, down to the rollers :D, early MIK though. Are you installing alternative rollers too? I was looking to the metal ones ¯\_(ツ)_/¯
    Tamarindo03 likes this.
  18. archetype
    archetype Squier-holic
    That's a pretty slick fix. Also known as trim washers.
  19. SoundDesign
    I use aluminium foil tape.
    campermoose likes this.
