Wiring help needed
Discussion in 'V.C.'s Parlor' started by gearobsessed, Apr 5, 2014.
  1. gearobsessed
    gearobsessed Squier-holic
    Aug 21, 2013
    new zealand
    I know i've asked for help but i really can't find a diagram on google.
    I'm working on a guitar for the lead guitarist in my band.
    It's got two humbuckers with two wires from each (not 4) and 1 volume, 1 tone and a 3-way blade/strat type selector switch.
    Someone please help!
  2. guitar guy
    guitar guy Dr. Squier
    Nov 3, 2010
    Tampa Bay Area
    for the humbuckers ignore the extra wires. black goes to ground, the other goes to either the pot or switch depending on the schematic.
  3. barakimou
    barakimou Squier-Nut
    574
    Jul 27, 2010
    Belgium
  4. gearobsessed
    Aug 21, 2013
    new zealand
    Thanks dude! But the blade switch i have isn't like any of those, it's 8 lugs in line, so which way would i wire that?
  5. barakimou
    574
    Jul 27, 2010
    Belgium
    this should help translating
  6. gearobsessed
    Aug 21, 2013
    new zealand
  7. gearobsessed
    Aug 21, 2013
    new zealand
    Stratshift, i followed that diagram intently. Only one of the switch positions work, and its the middle. But only the bridge pickup works :s
  8. stratmanshow
    stratmanshow Squier-Meister
    268
    Feb 7, 2014
    BC Canada
    do you have an ohmmeter? if so check the switch and write down which connects to what in the 3 positions. Usually but not always, the active pin is opposite to the position of the blade
    eg switch blade to the back, active pin at the front
    in any case your switch probably has a different configuration from the one in that diagram. It sounds like you may have the switch shown above as Import. That one shows the common output to the volume control at the center pins (which you would connect together)
    If you have 8 pins on a 3 way switch you'll probably need to bridge some of them. This may help
