Well, isn't that clever....
Discussion in 'Tech-Talk' started by Ace38, Mar 29, 2020.
  1. Ace38
    Ace38 Squier-holic
    Jul 19, 2016
    Tulsa, OK.
  2. squierTony
    squierTony Dr. Squier
    Jul 4, 2012
    MAUD Oklahoma
  3. Eddie
    Eddie Squier-Axpert
    I can use something like this. Would you have a link to the clip?
  4. Oldguitarguy
    Oldguitarguy Squier-Nut
    831
    Mar 2, 2019
    Nj
    mb doug, Kenneth Mountain and Eddie like this.
  5. squierTony
    Jul 4, 2012
    MAUD Oklahoma
  6. Ace38
    Ace38 Squier-holic
    Jul 19, 2016
    Tulsa, OK.
    Wiring instructions are in the video caption. I may have to try that myself.
    mb doug and Kenneth Mountain like this.
  7. Oldguitarguy
    831
    Mar 2, 2019
    Nj
    was looking for a link and found this connector. Cool way to power a pedal with a battery from the outside. According to Q&A, if you want to use for that purpose, you need to clip the wires and reverse polarity.
    5pack 9v Battery Clip with 2.1mm X 5.5mm Male DC Plug for Arduino by Corpco https://www.amazon.com/dp/B01AXIEDX8/?tag=squiertalk-20
  8. DougMen
    DougMen Squier-holic
    I don't understand why the jack needs to be reversed from the pickguard. Nevermind, my feeble brain just figured it out, lol. But, why would you need to be swapping pickguards that often? After several times you'll be stripping the screw holes in softer bodies, like basswood. I know that from trying too many different pickups in some Strats. Even harder Alder isn't immune. You still may end up with only 2 of the 11 stripped.
  9. I can't remove any Stratocaster pickguard I own with a 22 fret neck (shown in the video), without taking the neck off first.
    Can he remove & screw it down with one hand too?
    Kenneth Mountain and mb doug like this.
  10. Marko60
    Marko60 Squier-Nut
    857
    Oct 4, 2012
    England
    I was thinking if he only has one hand maybe guitar is not for him
    mb doug likes this.
  11. strat_strummer
    strat_strummer Squier-holic
    Nov 24, 2018
    RC addiction....
    I've seen other connectors used but not this, pretty cool...
  12. Ace38
    Ace38 Squier-holic
    Jul 19, 2016
    Tulsa, OK.
    I've been able to on all but one of my 22 fret necks. Pull back and up, off it comes.
  13. mofojar
    mofojar Squier-holic
    May 9, 2019
    Calgary, Alberta
    My Partscaster has a 22 fret neck and an aluminum pickguard. That one I have to take the neck right off to get under the guard. The other one generally can slide out but it's more flexible than the aluminum checker plate.
  14. optofonik
    optofonik Squier-holic
    I installed something similar in my Bullet Mustang but wrapped it in electrical tape so it's not quite as quick. This is kinda cool, though. Might negate the need to do a tape wrap.
  15. optofonik
    For recording, having a couple of "modular" guitars and several swappable PGs can save a lot of space. The trade off is time, of course. Just because PGs use quick disconnect wiring doesn't mean the PGs are quick-swap; it takes a bit of time so it's not something to do in a writing session. It only works for tracking well rehearsed material where a brief break may actually be welcomed.
  16. jamesgpobog
    jamesgpobog Squier-Meister
    391
    Feb 18, 2020
    SoCal
