Truss rod (no)problems?
Discussion in 'Squier Vintage Modified models' started by ManKonis, Aug 11, 2017.
  1. antiquityscion
    antiquityscion Squier-Meister
    265
    Aug 27, 2012
    phoenix,az
    So basically, either use heavier strings, or shim with a thicker shim, and it may correct the issue?
    ManKonis likes this.
  2. ManKonis
    ManKonis Squier Talker
    56
    Apr 25, 2017
    London
    Thank you all guys.
    I knew I am in the right place :cool:
    Lots of interesting information.
    I will play with the bridge a little bit and then probably change the strings to 11's.
    Anyway, even now guitar plays quite well, it's just needs a little little more relief.
    Thank you all!!!!:)
    theflow and so1om like this.
  3. rorygman
    rorygman Squier-Meister
    395
    May 9, 2017
    Barcelona
    @ManKonis - sorry for slightly hijacking your thread, but this seemed like the right place to ask this question!:
    Can anyone confirm the gauge of Allen key (hex wrench) used to adjust the truss rod on Squier Strats?
    All my tools are in the UK, so I can't check if i have the right one.
    I was going to buy the little Fender set of a big and tiny key, but they've sold out in my local place here.
    While I'm asking, what size is the tiny one used to adjust the bridge saddle heights?
    (You know, I have a feeling it's not going to be, one size fits all! ... it's for my Strat SE CAE-00 serial no.)
    so1om and theflow like this.
  4. theflow
    theflow Squier-holic
    Feb 16, 2017
    Palmetto,FL
    ROFL !!!!! That is priceless !:p
    rorygman and so1om like this.
  5. theflow
    Feb 16, 2017
    Palmetto,FL
    I agree and can relate !;)
    rorygman, so1om and 5ofeight like this.
  6. theflow
    Feb 16, 2017
    Palmetto,FL
    You are correct ,they vary ,I have one MIC that has an SAE sized nut!? The little one is for bridge saddles like you said and for bridges like on Jazzmasters where there is a hole on each end of the bridge you can raise and lower the ends of the bridge. I would start with a set of metric allen wrenches, 4mm to begin and test to fit going up from there. Jmho though others may have a better suggestion.;):)
    rorygman likes this.
  7. ManKonis
    56
    Apr 25, 2017
    London
    Don't worry, all thread is yours ;) I have my answers.
    So, I have a fender tool kit and hex keys doesn't fit with my Mij squier strat and Mii jaguar.
    Squier needs 1.5 hex key for the bridge saddles and 4 for truss rod.
    Fender kits costs a money so be sure if it really gonna help you.
  8. squierbilly
    squierbilly Squier-holic
    Apr 21, 2013
    sunny phoenix
    Shim has to be in the right spot to provide proper action...
    A flat or slight backbow would need the shim placed at the top of the pocket (in this diagram that would be the front) placed in the bottom (or back) would compound the problem..
    Raising the saddles also accomplishes the same result.. and would be my preferred method..
  9. Davis Sharp
    Davis Sharp Squier-holic
    Us guitar players don't know nothing 'bout concave and convex. We ain't educated good. We knows our letters up to G and numbers up to 6.
    Millennial? :eek::)
  10. 5ofeight
    5ofeight Squier-Nut
    850
    Nov 14, 2016
    Glasgow, Scotland
    Not in a thousand years...er...hmmm
    ManKonis, theflow and so1om like this.
  11. so1om
    No.. it wasn't a person, it was the entire engineering dept that did that. NOW... it proliferated through our company. So I started making fun of them by saying "Pringling Taco" and stuff like that. Then people look at me and I say "Well they made up frowny and smiley, why can't I make up silly words?"
    And *I'm* the bad guy.
    Davis Sharp, 5ofeight and theflow like this.
  12. Garyth
    Garyth Squier-holic
    Nov 14, 2013
    Florida
    just for you ....
    theflow, ManKonis and so1om like this.
  13. so1om
    Fret buzz? not wires tingling the metal bars on the long part of the thing?
    theflow and rorygman like this.
