string noise
Discussion in 'The Squier Bass Place' started by gary mitchell, Nov 11, 2019.
  1. gary mitchell
    gary mitchell Squier-Meister
    151
    Aug 23, 2019
    I have a lakland 3tbs hollow body , I use Fender Flatwounds on it. But i get a lot of string noise and rattle , its very noticeable, it all hollow but made from thick wood. anyone know how to cure this problem. Someone told me to put some foam under the strings close to the bridge, This is some what an expensive bass. lakland-skyline-hollow-body-bass_360_ab2dd04418179096748a8fb55f03d906.jpg
  2. Guitarmageddon
    nowhere
    Needs a setup I'd say - sounds like fret buzz. Proper truss rod relief, action height, and intonation then go from there....
  3. Tconroy
    Tconroy Squier-Nut
    910
    Sep 11, 2015
    kansas city mo
    If you dont know how to set it up take it somewhere
  4. drewcp
    If it's not fret buzz, and it is rattling at the bridge, it's possible one or more of the saddle height adjustment screws isn't secure/tight.
  5. wonkenstein
    wonkenstein Squier-holic
    Feb 3, 2017
    NH
    You definitely want a good set up, but with rattling or vibrating noises you also want to make sure all of your fittings are snug. Common things to look for would be all of the fittings at the bridge - make sure mounting screws are snug, make sure saddle height and intonation screws are snug. Another common thing I see on my bench is tuners loose in the head stock -make sure the bushings are snug and if your tuners have mounting screws make sure those are snug, too. Check the pickup rings and the truss rod cover, too. And when you're checking all the fittings and 'snugging them up' don't overdo it - hand tools only, no power tools and go easy.
    Every time you play your strings are vibrating. This is all stuff you can check periodically or at each string change. Some instruments just need that little TLC a little more often. A couple of the bass players I gig with will use a dampener just past the nut to keep resonances in check. No reason why you couldn't try a dampener at the bridge behind the saddles. But check all of your metal fittings to be sure. You'll get to know that bass a bit more, for sure.
    Lakland makes a few really fine playing and sounding basses - yours is a beauty!
  6. gary mitchell
    151
    Aug 23, 2019
    I went ahead and had a setup done on it, I got it done by a pro. He went plum through it and what ever he done it plays real nice now.
    -r3-, Best1989 and Guitarmageddon like this.
