Squier Standard Trem arm...
Discussion in 'Squier Stratocasters' started by Guzzik, Jan 11, 2019 at 4:34 PM.
  1. Guzzik
    Guzzik Squier Talker
    18
    Apr 21, 2015
    Wareham. Dorset
    Hi folks. The one thing I hate on my Standard is the Tremolo arm. It is over long and sits too high above the strings for me to "palm" it properly AND use the pick to play. I don't like using little finger etc for using it either so, is there a Tremolo arm out there that is shorter and doesn't bend up as far as the original that fits the Squier Standard?
    Cheers.
    John
  2. Papa Joe
    I've seen the shorter arms somewhere..Don't know where though..
    If it were me, I'd modify the one I had to suit me..
  3. Guzzik
    18
    Apr 21, 2015
    Wareham. Dorset
    Hi. Yeah, was thinking about that but, don't know how brittle the metal is for bending?
  4. Papa Joe
    You have good cause for concern..I used heat when I did it..It's touch and go with that..Then I dropped it in cold water after wards to re-temper it..If you don't it might bend when you're using it because it's still soft..
    Good luck with that..
  5. platefire
    platefire Squier-Nut
    865
    Sep 14, 2016
    North Louisiana
    My Squire Deluxe Strat arm was too high above the strings to play comfortably. I ended up sticking the short end with threads in the barrel of my 20 gauge shot gun(couldn't find any galvanized pipe) and pushed the long end down with a little pressure. The first time I bent it a little too far. I put it back in the barrel same way and prized back up a little and when I tried it this it was just right.
    BTW---the shotgun was unloaded. Platefire
  6. jjudas
    jjudas Squier-holic
    Mar 23, 2016
    Metro New Orleans
    I bend my trem arms. I haven't broken one yet.
  7. Guzzik
    18
    Apr 21, 2015
    Wareham. Dorset
    Ok, guys. Will be bending the arm then :). Thanks for the replies.
