Squier Bullet Tone Circuit
Discussion in 'Squier Offset Guitars' started by RegularJim, May 15, 2018.
  1. RegularJim
    RegularJim Squier-Nut
    700
    Dec 30, 2017
    Illiconsin, Wisinois
    Hi folks,
    Just acquired a new Imperial Blue Bullet Mustang. Cool guitar. I noticed today that the tone knob has no effect on sound unless the volume knob is turned all the way up. Is this normal, or is there a wiring flaw?
    Thanks!
  2. so1om
    so1om Squier-Axpert
    Chicago now Sarasota
    I think that something is amiss with the pot or wiring. You should be able to hear the sound become muted/bassy/muffled (insert your adjective here) when going from one extreme to the other.
  3. RegularJim
    700
    Dec 30, 2017
    The volume works great. The tone works great as long as the volume is 100% . Does anything stand out as wrong here?
    so1om and Kenneth Mountain like this.
  4. RegularJim
    700
    Dec 30, 2017
    SOLVED!
    The wire to from the volume to the tone was connected to the "wide open" lug on the volume pot, instead of directly to the output of the switch.
  5. RegularJim
    700
    Dec 30, 2017
    Now it's really solved. My last "solution" made the volume pot wonky. Here is the real solution. You'd think I'd be better at this by now! You'd also think they'd send you a guitar that's wired correctly. Both pots are "A250". Shouldn't the volume be a "B250"? Come to think of it, this thing has humbuckers. Shouldn't they be 5o0K?
    JK202 and so1om like this.
  6. dbrian66
    Glad you got it figured out. That’s crazy that a brand new guitar was wired up wrong.
  7. rbh32
    rbh32 Squier-Meister
    441
    Feb 12, 2018
    Valley, AL
    I’ll have to look at my wiring when I get around to changing my pots. Glad you caught that and let us know. Thanks. And yes, I think it should be 500k pots too.
  8. so1om
    so1om Squier-Axpert
    Glad it worked out.
    Let's say you were blind and you didn't know if is said 250, 500, 1000000000. How does it sound?
    one of my quirks is getting a guitar.. "hey.. how does this sound? great, cool. let me play." (I sound like Joe Walsh..)
    I am not sure of the pot values in my HH bullet strat (one vol, 2 tones) but I like the range it gets.
    Try it out for a while and then see what others are saying about pot values. it may be an insignificant issue.
    I will say that I absolutely love the odd clean sound of these humbuckers compared to Gibson T tops and the humbuckers in the Epiphones. Humbuckers... but different.
    VealCutlet and RegularJim like this.
  9. RegularJim
    700
    Dec 30, 2017
    It's probably all for the best that they're 250's. As it is, it's very bright and trebly. 500's would make is even more so, right?
    so1om likes this.
  10. so1om
    so1om Squier-Axpert
    Likely.. which may be the key to why I like mine? So if it suits your needs, run with it! That Mustang HH you have is a great one.
  11. RoyalWe
    RoyalWe Squier-holic
    Sep 5, 2012
    Eugene, Oregon
    Yeah, I don’t have this issue with the tone not working on my mustang HH either. Must have just been a goof from the factory. As far as pot values go, I don’t know what to think. I feel like the neck pickup is a little too dark, so 500k’s would help that out...but the bridge is already so spanky, don’t know how much brighter it would get too.
  12. JK202
    JK202 Squier Talker
    34
    Jan 17, 2017
    Arlington VA
    Hey guys, I got my Bullet Mustang a month or so ago and my Tone pot doesn't function either. Weird. I'll delve deeper soon and hopefully this solution will work for me. Thanks Regular Jim - it's been a few months, do you remain satisfied with the guitar?
    Cheers,
    JK
    lavenderphonk likes this.
  13. RegularJim
    700
    Dec 30, 2017
    It's long gone.
  14. blackspider57
    blackspider57 Squier-holic
    Mar 11, 2017
    Montana
    Just got another Bullet Mustang (#3) and it has this same issue. Volume full blast, tone control works perfectly. Back off the volume, even a bit and tone control does nothing. Must be from the same shift as yours. I will get it corrected. Thanks for the tip :) Even though your guitar is "long gone" it is still helping others!!
    lavenderphonk, Mr Bones and so1om like this.
