"Shark" build
Discussion in 'Squier Telecasters' started by beerbelly, Apr 1, 2019.
  1. Triple Jim
    That sheds light on your unusual ability to create pieces of art, which in this case is guitars. My daughter has a degree in design and is also an artist. I see similar perfection in her work, although it's largely fashion design with drawing and painting on the side.
    beerbelly likes this.
  2. John L Rose
    John L Rose Squier-Nut
    875
    Mar 16, 2016
    Sackville, NB, Canada
    So, no string tree for it, I guess.
    Even better. It still looks cool.
  3. beerbelly
    beerbelly Squier-Meister
    190
    Jan 30, 2013
    Oregon
    I primed the body with Duplicolor sandable white lacquer primer, and ordered some Krylon Acryli-Quik Smoke Gray lacquer for the color coat. Going for the shark-y color this time around.
  4. beerbelly
    190
    Jan 30, 2013
    Oregon
    Mocked it up after spraying the body gray. I think this color makes sense based on the guitar's name, and I haven't seen too many gray guitars. Still need to add clear coats and polish it.
    BBQedIguana and Triple Jim like this.
  5. beerbelly
    190
    Jan 30, 2013
    Oregon
    8 coats of clear on the body over the last 2 days. I also sprayed some more amber on the neck to darken it some- it was looking a little too light to me.
    BBQedIguana likes this.
  6. beerbelly
    190
    Jan 30, 2013
    Oregon
    Finally got it done, and I'm real happy the way it turned out. By lowering the neck pocket 1/8", I was able to adjust the trem saddles down to half the height they used to be for much lower action.
    Gray Shark done A.JPG Gray Shark done B.JPG Gray Shark headstock.JPG Gray Shark saddles.JPG
  7. BBQedIguana
    BBQedIguana Squier Talker
    69
    May 8, 2020
    AWESOME!!! Excellent job! :)
    Ricky3Fingerd likes this.
  8. Ricky3Fingerd
    Ricky3Fingerd Squier-Nut
    906
    Nov 26, 2019
    Canda
    Holy shiatsu. Wow. Amazing job.
  9. Triple Jim
    BB, you need to be custom building guitars for the big names.
  10. Black Strat
    Black Strat Squier-Nut
    923
    Nov 30, 2014
    Virginia
    It looks like you have room for a single coil in the middle position? Or a blade type humbucker! Your build looks AMAZING!
  11. Toddcaster64
    Toddcaster64 Squier-holic
    Apr 1, 2013
    Ventura
    Just phenomenal. Seriously.
