Rail split with mini toggle question
Discussion in 'Tech-Talk' started by squierTony, Oct 12, 2019.
  1. squierTony
    squierTony Dr. Squier
    Jul 4, 2012
    MAUD Oklahoma
    I have a guitarheads mini rail in my Tele and want to split it with a mini toggle switch. It's a 5 wire pickup so do I just use the wires that are taped together on the switch? The taped wires are red and white.
  2. Triple Jim
    If you use the switch to ground the red-white junction it should do what you want.
  3. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    It's a 2 pole switch if that matters..
  4. mkgearhead
    mkgearhead Squier-holic
    Dec 18, 2009
    Fort Morgan, CO
    That should work just fine. One side to ground, one side to the red/white wires.
  5. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    So leave the red and white together on one pole
    and ground the other pole?
  6. mkgearhead
    Dec 18, 2009
    Fort Morgan, CO
    Exactly.
  7. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    Got it. I'll try it out tomorrow.. Thanks
  8. Triple Jim
    All correct, except that's a single pole, single throw switch, for information's sake. "Pole" refers to a set of switch contacts.
  9. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    Ok so I did this and nothing changed in the tone when the switch position is moved. Both positions sound exactly the same.
  10. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    I've got
    Black to switch
    Bare copper to top of pot
    Green to top of pot
    Red and white together to switch
    Second pole to ground
  11. mkgearhead
    Dec 18, 2009
    Fort Morgan, CO
    Can you post a pic of the wiring?
  12. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    Tried a new switch and BINGO!!!!!
    Evidently the switch was cr@p...
    drewcp, Guitarmageddon and mkgearhead like this.
  13. squierTony
    Jul 4, 2012
    MAUD Oklahoma
  14. Triple Jim
    Nice single coil sound with switch "on"?
  15. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    Not really single coil but less power and a slight bit of twang. I thought it would shut off one of the coils but I'm not smart enough to wire it like that lol.
  16. Triple Jim
    It you have it wired corretly, it is indeed shutting off one of the coils. If it's a particularly hot pickup it may not sound like a typical single coil though. I know when I split it, my JB Jr. single coil sized humbucker doesn't sound quite like the original single coil that was in there.
    As @mkgearhead suggested, if you want to post a couple good photos we can check the wiring. You said you have the black and the green going to the top of the pot. The green should go to the pot's end terminal that's not grounded to the pot's case.
  17. squierTony
    Jul 4, 2012
    MAUD Oklahoma
    It's all back together now and I really don't want to pull it back apart but the wiring is as I posted above.
    Black to switch
    Green to top of pot
    Second pole to ground..
    And you may be correct about it shutting one off and not sounding like it. I tapped both blades with a screwdriver and both sounded like they were on but I could definitely be wrong.
  18. Triple Jim
    According to this, you have grounded the green output wire of the pickup. That would result in no sound at all. That's why I questioned it.
    If it's working, you must have connected the green to the hot terminal of the pot (not with the bare wire).
    Guitarmageddon likes this.
  19. radiotech
    My experience with rail pups is that S/P almost always sounds better than split... and maintains hum cancelling.
