Question about body seams
Discussion in 'Tech-Talk' started by blackspider57, Mar 15, 2019 at 9:12 AM.
  1. blackspider57
    blackspider57 Squier-Nut
    792
    Mar 11, 2017
    Great Falls Montana
    So based on all of my experiences, one would expect body seams to run parallel to the neck? On this guitar, they run both parallel and perpendicular. Is it possible this body is a mishmash/checkerboard of different pieces of wood? Does not matter to me in the least, just curious.
  2. so1om
    I couldn't tell. Weird! Could be a few possibilities...
    they make the entry level our of whatever glued up wood. The shape is the shape. Or it was a hunk of glued up wood that was used as a tooling setup or a paint set up and somehow got mixed in. The use of scrap or B materials to do a setup is common and they could escape. OR maybe some odd anomaly in the finish.. Interesting
    Big tuna and Kenneth Mountain like this.
  3. VMamp
    VMamp Squier Talker
    62
    Jan 28, 2019
    United Kingdom
    Can you see the same on the back?
    Kenneth Mountain and so1om like this.
  4. I have never seen that before! Is it a Squier? What year is it made?
  5. Kenneth Mountain
    Kenneth Mountain Dr. Squier
    Jan 27, 2016
    North Tonawanda, NY
    bronco bass - never saw a perpendicular seem ?
    Big tuna and SoundDesign like this.
  6. blackspider57
    792
    Mar 11, 2017
    Great Falls Montana
    Yes,
    but two on the front, only one on the back?
  7. blackspider57
    792
    Mar 11, 2017
    Great Falls Montana
    2016 Squier Bronco bass.
  8. blackspider57
    792
    Mar 11, 2017
    Great Falls Montana
    A bit odd,
    however, this bass gave itself a name.
    The "Kibbles & Bits bass". I had never seen a perpendicular seam before, and just was wondering, as I often do about such miniscule stuff. Plays great, sounds surprisingly robust, and if I close my eyes this imperfection just disappears :)
  9. Guitarmageddon
    Guitarmageddon Squier-holic
    Those aren't body seams, they are sinks in the finish due to different densities of wood within the same piece of wood - also known as grain patterns.
    Las Palmas Norte likes this.
  10. Would all three pieces of wood all line up the same if that where the case, in a seemingly straight line?
    I can't see the lines in the video, but I'm assuming they are like the lines illustrated in the diagram. Either way, I've never noticed that before.
  11. blackspider57
    792
    Mar 11, 2017
    Great Falls Montana
    Very interesting. Likely exactly what I am seeing.
    I had just never seen such a thing on any of my guitars and was curious.
    Is this more obvious on a black guitar?
    Thanks for sharing that!:)
  12. blackspider57
    792
    Mar 11, 2017
    Great Falls Montana
    Just like the lines in the illustration,
    perfectly straight.
  13. Kenneth Mountain
    Jan 27, 2016
    North Tonawanda, NY
    I have seen many guitars that have been exposed to extreme temperature changes - most seemed to show the seams between the wood - the finish expanded and contracted ?
