No Adjustment Holes Pickguard Installation
Discussion in 'Squier Telecasters' started by Uncle Joe, Jul 18, 2019.
  1. Uncle Joe
    Uncle Joe Squier-Meister
    210
    Dec 18, 2015
    Jersey
    Last weekend my new 2019 Squier Telecaster Bullet Red Sparkle arrived at my doorstep. Nice guitar. I wanted something to jump-start my enthusiasm for playing as I relearn old songs long forgotten and add one or two to the repertoire. I had no intention of modifying it, other than the pickguard. When I saw the guitar had shipped, I ordered a black/red/black eight hole, no adjustment screws, from Stratosphere. That arrived on Monday.
  2. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    Wow. I struggled with images on this. Here's the guitar alive on arrival:
    dbrian66, daan, Viking and 3 others like this.
  3. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    Here's the original pickguard alongside the Black/Red/Black Stratosphere replacement:
  4. Kenneth Mountain
    how do they line up ?
    dbrian66 and JurnyWannaBe like this.
  5. Kenneth Mountain
    Are you asking about mounting the neck pup into the body ? or just drillin holes on the new PG ?
  6. Eddie
    Eddie Squier-Axpert
    You may need to drill.
  7. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    The replacement black guard in the above image still has clear protective film adhered, but as you may be able to see, it doesn't have the pickup adjustment screws drilled through. That's what I wanted.
    The Squier Limited Edition Bullet Telecaster Red Sparkle is a pretty great guitar right out of the box. I like the classic features of recessed ferrules, cup input, single tree and low output pickups and can easily live with the fully functional modern hardware; bridge and sealed tuners. What I'm not a big fan of is the visibility of the neck pickup adjustment screws on the OEM pickguard. Plus I think Red looks better with a Black guard. Minor thing, right?
    Kenneth Mountain and drewcp like this.
  8. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    Yes, I need to drill. First I thought about making a shim and drilling through that. So I did.
  9. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    The problem was I didn't think it would be sufficient for holding these awesome nuts I found at Lowes.
    Kenneth Mountain, so1om and drewcp like this.
  10. mtjo62
    mtjo62 Squier-Meister
    377
    Center and mount the pickup at the back of the cavity right in tho the body. Use a piece of foam under the pickup to act as a spring for adjustment.
  11. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    The above nuts fit the size and thread of the stock pickup screws perfectly. My concern was that I left the CAD cavity cutouts exposed and was afraid my shim was too thin of a gauge to hold the Lowe's nuts securely. So I decided to fill the pickup cavity depressions with plugs cut from scrap wood. I cut them using a mitre box saw and rounded the edges with sandpaper.
    Kenneth Mountain and Viking like this.
  12. Uncle Joe
    210
    Dec 18, 2015
    Jersey
  13. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    Then I filled the gaps with toothpicks, wood dust and wood glue. Once dried, I covered the plugs with a modicum of Plastic Wood. Once sanded down, the graphite shielding paint that I sanded from alongside blended atop and covered the plugs a bit. Works for me.
  14. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    If I have time tonight I'll drill for the adjustment nuts.
  15. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    Not too badly. There will be two crooked installation screws I think.
  16. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    I'm attempting to offer a tutorial on drilling the body. I didn't think the most difficult part would be my failure to upload images correctly! Oops. I'm learning quite a bit on this little project.
  17. so1om
    so1om Squier-Axpert
    nice work so far!
  18. so1om
    so1om Squier-Axpert
    Kenneth Mountain and Uncle Joe like this.
  19. Uncle Joe
    210
    Dec 18, 2015
    Jersey
    Thanks. That does help. I got lucky and found the part in brass at Lowes. I had no idea what I was looking for until I found it. When the 6-32 actually fit the stock pickup adjustment screw I felt like I won a scratch-off lottery. Now that my prep work is complete, let's see if can install this thing successfully.
    Kenneth Mountain, drewcp and so1om like this.
  20. so1om
    so1om Squier-Axpert
    well it says 1/4" drill bit for the pilot hole. it would be better to be a smidge larger than too tight.
    Uncle Joe and Kenneth Mountain like this.
