NGD! 1983-84 Squier Bullet
Discussion in 'Japanese Vintage Squiers' started by 73rhc, Dec 10, 2016.
  1. squierbilly
    squierbilly Squier-holic
    Apr 21, 2013
    sunny phoenix
    Make sure the ground and hot wires on the input jack have not been switched.. (check with a multi meter).. it can be difficult to tell which post is which with the necked eye because of the layering.. they get mixed up a lot..
    P.S. try a different guitar cord.. may cause problems also..
  2. txflood
    txflood Squier-Meister
    309
    Dec 10, 2014
    North Carolina
    I have a stock MIJ E6 bullet and I would have to say it has the most hum of any of my guitars. The noise is going to vary depending on the environment you are in and the electrical wiring and devices that are around, but all things being equal my bullet is still more noisy than my other single coil guitars.
    The middle pickup is not RWRP so there is no hum cancelation in positions 2 and 4. Like someone already noted on their guitar, I would say the noise is worse in those positions since now you have 2 pickups contributing 60 cycle hum.
  3. Squi-Guy
    Squi-Guy Squier Talker
    9
    Jan 3, 2017
    Toronto
    You're exactly right, it definitely gets louder in those positions... But, I've learned to deal with it. The feel of that neck just makes everything alright.
  4. Acidhouse
    Acidhouse Squier-holic
    Sep 16, 2010
    Birmingham . . . Alabama
    Don't deal with it. You can chase it down. A couple of times I've had the issue and it was the grounding wire that goes back to the Trem plate.
    psp742 and 73rhc like this.
  5. 73rhc
    73rhc Squier Talker
    34
    Dec 10, 2016
    Montreal, Quebec, Canada
    Nice axe!!! Mine did not come with the case. But I already had one. So they will pair nicely.
    psp742 likes this.
  6. 73rhc
    73rhc Squier Talker
    34
    Dec 10, 2016
    Don't know if you've seen this article. I found it interesting.
    http://www.prosoundweb.com/article/eliminating_troublesom_hum_buzz_created_by_electric_guitars/
  7. 73rhc
    73rhc Squier Talker
    34
    Dec 10, 2016
    I checked again. This time at a louder volume. I'm getting the same hum in all positions. Tried another cable and got the same result.
  8. Squi-Guy
    9
    Jan 3, 2017
    Toronto
    It looks like what txflood says is accurate, the middle pickup is definitely not reverse wound reverse polarity.
  9. bass player
    bass player Squier Talker
    4
    May 6, 2016
    Toronto
    I also have an '83 Bullet SQ w/OHC. No such hum on mine - just a bit of crackling when turning the volume knob. Bridge pickup was replaced to a rail by previous owner.
    Cheers!
  10. Allenjason95
    Allenjason95 Squier Talker
    77
    Jun 17, 2017
    Sweetlips Arkansas
    What's the difference between the SQ series and yours? I just bought one, it is an SQ but I honestly don't know what that means other than "squier".
  11. 73rhc
    73rhc Squier Talker
    34
    Dec 10, 2016
    SQ is a date identification. Guitars made in Japan between 1983 and 1984.
  12. Allenjason95
    77
    Jun 17, 2017
    Sweetlips Arkansas
    Thanks.
