Monoprice Amp Questions
Discussion in 'Amp-a-ridifiers' started by jbrowning, Jan 10, 2020.
  1. jbrowning
    jbrowning Squier-Nut
    516
    Jan 28, 2019
    colorado springs
    So I have a couple/few questions for you all.
    How does the 15 watt amp compare to the little 5 watt amp Monoprice has?
    With the 15 watt amp, who are using pedals and what pedals are they and what effects are you getting out of them? (I've never used any pedals)
    Thanks and I'm sure I will have a lot more questions coming up this weekend.
    Jim
  2. RegularJim
    RegularJim Squier-Nut
    687
    Dec 30, 2017
    Illiconsin, Wisinois
    I have the 15 watt, and I don't use any pedals at all. It does fine without them.
    Disclaimer: I don't gig, and my equipment never leaves the basement.
    It is my understanding that the 5-Watt model is a different animal. It has 6L6 tubes instead of the EL84 or whatever. I'm not sure what the difference is, honestly.
    I recommend you turn the knobs until it sounds good. Don't try to make it sound like a Fender, Marshall, etc. It has it's own personality. If you try to compare it to something that it's not, you might be disappointed.
  3. RetiredNSquired
    RetiredNSquired Squier-holic
    Jun 20, 2018
    Canton, Ga
    From my understanding, the 5 watter is much more of a Champ-type. ( Tube differences mentioned above, plusthe tone circuitry totally different than the 15,). My MP15 definitely had it's own voice. I generally describe as a Blues Jr, AC15 hybrid ( I put an Emmenance Cannabis Rex in mine).
    On my pedals, I have a Caline Midlander, which is a TS type OD, Joyo Sweet Baby OD and Joyo American Sound which is awesome for tone shaping and let's me get into Tweed territory. All into the amp input. In the FX loop I have a Mooer chorus Ammoon delay a looper and a Behringer EQ. These give me plenty of range of sounds to satisfy me.
    surf green, jbrowning and drewcp like this.
  4. jbrowning
    516
    Jan 28, 2019
    colorado springs
    The reason why I was asking about the 5 watt amp is because I can bring a amp to my work place and practice at lunch. Now I know there is no reason I would need to use the 15 watt amp at 15 watts, the 1 watt setting would be plenty loud enough. So I was wondering if the 5 watt amp would get me the same sounds as the 15 watt amp does?
  5. mkgearhead
    mkgearhead Squier-holic
    Dec 18, 2009
    Fort Morgan, CO
  6. Mr Bones
    Mr Bones Squier-Nut
    659
    Oct 17, 2019
    Kansas Territory
    I have both, th 5 Rocks jus fine, more after work... :)
    Highly recommend, Mr. Bones approved!
    surf green and jbrowning like this.
  7. Triple Jim
    Note that the 15 has a master volume but the 5 does not. If you need to be really quiet, the 15 can do it better.
    duzie, jbrowning and drewcp like this.
  8. TimTheViking
    TimTheViking Squier-holic
    If I were you, I'd just get something like a Roland Micro Cube or a Line 6 Micro Spider. That way you'd have some effects that you could have at low volume. Even at the 1 watt setting you'll still be pretty loud if you want some crunch.
    jbrowning likes this.
  9. bgmacaw
    bgmacaw Squier-Nut
    868
    Jan 19, 2018
    GA USA
    I have the 5w and it gets quite loud, loud enough to annoy my wife if she's watching Bridezillas downstairs.
    My take-to-work amp is a Vox Mini3. It's small, battery powered portable and sounds good.
  10. DougMen
    DougMen Squier-holic
    The Boss Katana Mini is very small, can run on batteries, has great clean and drive sounds, and has a great sounding delay built in. It, along with the Fender Mustang LT25 and Yamaha THR10C, has become my favorite amp for low volume playing with great tone and tube like feel. And I believe the 5 watter uses a single 6V6 power tube, not a 6L6.
  11. Jim Belaye
    Jim Belaye Squier-holic
    Jul 25, 2015
    Montréal, Canada
    I have the 15 Watt. I use pedals with it, OD, Distortion, Fuzz in front and modulation, delay in the loop.
    It also sounds pretty good on its own, very good clean sound. The crunch tone is also very good.
    IMO it's a very good amp for Classic Rock and Blues. The mono 15 Watt is a clone of the Laney Cub 12R.
  12. Mr Bones
    Mr Bones Squier-Nut
    659
    Oct 17, 2019
    Kansas Territory
    This is absolutely so...^
    Do please note that th 5w also has a 1w attenuator, as well...
    All but 2 of my YT vidjas I've posted used my MP5, cept fer th one I did over at Mistah Cholly's, (acoustic), an my soundcheck on th CAR, I used my Gorilla GC-25
