Modulating between songs of different keys
Discussion in 'Music, Theory, Tab and Such' started by DADGAD, Jan 17, 2018.
  1. DADGAD
    DADGAD Squier-Meister
    294
    Nov 1, 2017
    California
    This weekend, I will be performing five songs with the band. The songs are all in different keys, necessitated by the fact that there will be different singers for each. I need help with what cords to play at the end of each song to musically modulate to the beginning of the next song.
    Can you suggest a chord progression or formula that I can uses to get there?
    The keys are E, A, G, C then D.
    Thanks!
  2. plangentmusic
    plangentmusic Squier-holic
    Jul 4, 2012
    manhattan
    Just go to the 5 chord of the next key. Works every time.
    DADGAD likes this.
  3. MikeyH
    MikeyH Squier-Meister
    250
    Jan 2, 2017
    Hawaii
    Makes sense! Wish someone had told me that long ago.
  4. DADGAD
    294
    Nov 1, 2017
    California
    Thanks, guys. One song is in G and ends on a G chord. The next song is in C, and the fifth of C is the G chord. So there would be no modulation chord. Right?
  5. Roccobagadonuts
    Roccobagadonuts Squier-holic
    Sep 8, 2010
    Remulak
    Yea, seems like you would be there already with that switch. As the 5th chord in C would be a G major... Which is the 1 chord in the key of G...
    What starts to confuse me with the whole key changes thing is when I hear stuff like what Planet says... "Just go to the 5 chord of the next key. Works every time"... But then I think ok, say im in G... And im switching to the key of E at some point... If I went to the 5th chord of E as the switch like he says, which would be B major, I would start to clash with the notes that are in the key of G right from there start... The original key being played at 1st before making the switch to the key of E... As in the end the notes in the key of G are G A B C D E F#... While a B major chord would be like B D# and F#... And thats before getting into the "entire" key of E which contains even more clashing notes when compared to the key of G where there is just a single sharp, F#... I must be missing something when it comes to the tricks of trade on key changes/modulation that holds me back from "getting it"..
    That being said it seems like the switch your looking at is a much easier proposition. Goin from the key of G to C and changing over on the G major chord is a rather easy task when compared to some other leaps go as far as key changes go thats for sure... Planet, is there an easy way to explain while going to the 5th chord of the new key as the "setup" to a key change will "work" and not set up further clashes down the road as far as the next chord/notes go??? Why the 5th??? It starts u off with less clashing notes quite often on that 1st key change set up chord? Before getting into more "off" notes as you start to flow into the "new" key???
  6. Papa Joe
    Yeah there is..You can use a G7th before the C...Or an Gaug, which is what I sometimes use there..
    DADGAD likes this.
  7. squierTony
    squierTony Dr. Squier
    Jul 4, 2012
    MAUD Oklahoma
  8. DADGAD
    294
    Nov 1, 2017
    California
    Only if they make a capo for singers. ;)
    radiotech likes this.
  9. Papa Joe
    Another thing that can sometimes work is to stop playing for one bar and pick up in the new key..
    radiotech and DADGAD like this.
  10. radiotech
    Hahahaha!
    If Only!
  11. johnnywizzo
    johnnywizzo Squier-Nut
    515
    Feb 4, 2016
    A tourniquet on the neck?
