Minor Epiphone SG G-400 Upgrades
Discussion in 'Other Guitars' started by kcchiefs, Mar 29, 2020.
  1. kcchiefs
    kcchiefs Squier-Meister
    372
    Dec 12, 2011
    Illinois
    I replaced the stock nut and bridge on my SG - Graphtech Tusq XL 606000 and Tonepros T3BT-C Metric bridge. Whoever worked on the nut before had cut the low E nut slot very deep. The G string had an annoying buzz at the bridge. Only had to do minor sanding on the nut to get it to fit and the bridge fit right onto the existing pins. I did have to raise the tailpiece a small amount so the strings could clear the edge of the new wider than stock bridge.
    Rat cam 68, billyb, Shaytan and 9 others like this.
  2. Oldguitarguy
    Oldguitarguy Squier-Nut
    831
    Mar 2, 2019
    Nj
  3. RoyalWe
    RoyalWe Squier-holic
    Sep 5, 2012
    Western Oregon
    I’ve thought about upgrading the rattley bridge on my firefly. How does the metric affect the string spacing on the fretboard? Sounds like it’s a wider string spread, but the strings don’t look perilously close to the edge of the fretboard.
    mb doug likes this.
  4. kcchiefs
    372
    Dec 12, 2011
    Illinois
    I think the string spacing is identical. But I will double check. No more annoying buzz and it is locked in place.
    RoyalWe and mb doug like this.
  5. DrBeGood
    Both Epiphone and Firefly are metric. Good job on that SG.
    Now for added tuning stability, you should learn how to lock those strings on tuner posts.
    Another thing you can try, is to top wrap the tail piece. I do it to get a gentler angle, that I feel makes for easier string bends. I have to say I like the look too.
    Rat cam 68, RoyalWe and ToneChaser77 like this.
