MIM high mass bridge upgrade. 19.99
Discussion in 'Squier Stratocasters' started by Tool, Feb 14, 2020.
  1. Tool
    Tool Squier Talker
    36
    United states
    Read great views other than the saddles. What ideal saddle is recommended for these?....going in a SE. Can the block be changed to steel or does it really matter?
    Ricky3Fingerd, duggerh and mb doug like this.
  2. Guitarmageddon
    North Pole
    The Fender MIM Standard big block trem? They are great.....and so are the saddles.....no need to change them.....would drop right into an SE, just keep and re-use your claw/springs and you'll need a new trem arm too for this new bridge......
    It's more the mass of the block than what metal it's made of - no need to change to steel.....
  3. Eddie
    Eddie Squier-Axpert
    I use these in all my full body Squiers. Perfect fit. Can't go wrong with them. Use as-is ... drop 'em in, screw 'em down, and let 'er rip. :)
    Tool, Ricky3Fingerd and mb doug like this.
  4. BT224
    BT224 Squier Talker
    99
    Feb 7, 2020
    DFW
    Is the MIM different than the MIA?
    mb doug likes this.
  5. Guitarmageddon
    North Pole
    Yes, the MIA American Standard is a totally different tremolo bridge with 2 point mounting, 56mm spacing......
    To upgrade most full thickness body 6 screw trem modern Squier Strats, the MIM is the one to use.....
    drewcp, Ricky3Fingerd, Caddy and 2 others like this.
  6. ToneChaser77
    ToneChaser77 Squier-Meister
    322
    Sep 29, 2019
    Milledgeville, Ga
    Yes. Newer MIA is two post design and the vintage style americans have a different string spacing and thus different screw placement.
    mb doug likes this.
  7. BT224
    BT224 Squier Talker
    99
    Feb 7, 2020
    DFW
    Thanks, always wondered.
    mb doug likes this.
  8. Tool
    Tool Squier Talker
    36
    United states
    Yes thats the one..i dont use the trem arm. Any differences in tone with 3 or 5 springs? Wonder why all i ever see is 3 on guitars
    Ricky3Fingerd likes this.
  9. Guitarmageddon
    North Pole
    If you don't use the trem arm and don't float your bridge, it's not worth upgrading from your SE bridge at all.....keep the stock one....
    The resonance is instead gained because of hard contact with the body....so there's no need to use a bigger block......
    ToneChaser77 and Tool like this.
  10. Caddy
    Caddy Dr. Squier
    And on the other hand my new MIM Players Series Strat has the two point trem. First guitar I have had with that and really like it better.
    ToneChaser77 likes this.
  11. Tool
    Tool Squier Talker
    36
    United states
  12. Tool
    Tool Squier Talker
    36
    United states
    Ive never seen a bad neck pocket. This must be it
  13. Guitarmageddon
    North Pole
    SE neck pockets are usually always like this...it's not an issue.....
  14. Ricky3Fingerd
    Ricky3Fingerd Squier-Meister
    429
    Nov 26, 2019
    Canda
    Rodiebobw and Tool like this.
  15. Tool
    Tool Squier Talker
    36
    United states
    Rodiebobw and Ricky3Fingerd like this.
  16. Ricky3Fingerd
    429
    Nov 26, 2019
    Canda
    Np. Honestly the block and plate and arm are great. The saddles are the bent steel ones and one stripped almost immediately. Under very little tension. So it is 36 plus another 12 for stainless saddles so maybe not as good a value. Steel though.
    Tool likes this.
