Made a volume box tonight. And footswitch the next.
Discussion in 'The Buzz Box' started by rbh32, Nov 7, 2018.
  1. rbh32
    rbh32 Squier-Meister
    169
    Feb 12, 2018
    Valley, AL
    Wow it’s late!!! But I got it done bc I just couldn’t stop once I got started...
    I had a slight problem with an order of foot switches to make a channel footswitch and some other things, and while I was waiting, I decided to try to make this volume box to go in my effects loop.
    It’s no marvelous invention, just a master volume, and since I didn’t have one, I thought “why not.” And I fixed my battery powered amp while I was at it.
    It’s in this little enclosure, and I thought I messed up at first when I test fitted, but it ended up working once I got it all wired up. Nothing touches , and I was really relieved that I successfully crammed it all in there.
    Anyway, here’s the pics...
    FE602FDA-FC87-4737-AC41-19811E76DCFA.jpeg 2632B425-705A-4C2F-AA55-BF74F1A04361.jpeg 00CD644A-8B92-4929-9278-A5D91DAC0833.jpeg
  2. gearobsessed
    gearobsessed Squier-holic
    Aug 21, 2013
    new zealand
    That looks awesome! Great job!
    Can you adjust it with your foot?
  3. rbh32
    169
    Feb 12, 2018
    Valley, AL
    Thanks!!
    I guess you could, but I was planning on putting it in my effects loop with some patch cables and sitting it on top of the amp.
  4. SoundDesign
    I'm curious how you're deploying this / what it's doing for your FX chain.
  5. rbh32
    169
    Feb 12, 2018
    Valley, AL
    Basically what I’m going to use it for is just a master volume. Maybe turn it to 10, adjust the other volumes/gain until I like it, then turn this volume down and see if the tone stays the same, or turn it low and do the same thing, but in the opposite direction as far as pure volume. I realize it might not, which is why I’m not really expecting anything amazing. And if something amazing does happen, then so be it. :D
  6. fattboyzz
    fattboyzz Squier-Nut
    978
    Cool & simple little way to geterdone !
  7. so1om
    Handy Dandy.. Looks pro!
  8. rbh32
    169
    Feb 12, 2018
    Valley, AL
    Ok, it’s definitely just a master volume, but I’m glad I did it. I like how I can set both channels to unity, and then just mess with that one volume for the amp. And it’s more subtle sweep, so I can “fine tune” the sound with a little more precision. I like it set at 10 to begin with so I can set a max volume, and I can crank it and know I’m not going to overdo it.
    I guess I forgot how useful a MV can be. :)
    Now on to the footswitch! :D
  9. rbh32
    169
    Feb 12, 2018
    Valley, AL
    DC5C358A-1CDF-4416-9912-27FB8FCFE635.jpeg 746400D2-2FDF-41F7-BBC5-6652F49CD31F.jpeg And just got done with this footswitch tonight. I am thinking about putting in an LED, but I’ll have to play around with what resistor to use and which lugs to solder to, so I just made it simple so I could add one later if I wanted. F16B5488-3D2B-473F-83CB-7D3BC35DF209.jpeg
  10. spyhawk36
    spyhawk36 Squier-Meister
    101
    Sep 23, 2011
    Detroit
    That’s rad. I like that idea
  11. Tconroy
    Tconroy Squier-Nut
    519
    Sep 11, 2015
    kansas city mo
    so it is more like a volume pedal as not to change the tone when you have high gain? On the guitar you get a cleaner sound when you back off the volume. does this hold your tone so it is more at bedroom level volume while still having the high volume sound?
  12. rbh32
    169
    Feb 12, 2018
    Valley, AL
    It works , sort of. It’s not a full blown attenuator (I think that’s the spelling), but it doesn’t kill all the tone like when you turn the volume down on the guitar, no. I guess because it’s in the effects loop it does that, maybe?
