Jazzmaster affinity toggle switch wiring help please.
Discussion in 'Other Squiers' started by geckogiss, Apr 11, 2018.
  1. geckogiss
    geckogiss New Member
    2
    Apr 11, 2018
    Hi , I received my new Jazzmaster affinity, however when it arrived the toggle switch was damaged. Instead of sending the guitar back the shop sent me a replacement toggle switch which looks different to the original.
    Please can someone of greater knowledge help me how to wire this as I don't have much knowledge. I should add the toggle switch at the front is the replacement
  2. Gem23
    Gem23 Squier-Meister
    261
    Apr 11, 2017
    Somerset, UK
    I'd get them to send the same bloomin toggle switch, or take the guitar back and get one that works.. what kind of customer service is that???
    The commercial world is going downhill rapidly...
    Sorry I can't help
  3. TheKurdtz
    TheKurdtz Squier-holic
    Sep 13, 2017
    Holland
    Okay, listen up:
    the outer pin in the middle is your ground(Green)
    your middle connector is you active output (Blue)
    and the connectors next to that are for the pickups (Red and Yellow)
    i have to mention that your new switch will be of poorer quality than your old switch, but i think that won't matter too much.
    Gem23 and Caddy like this.
