Help needed - neck crooked sideways
Discussion in 'Tech-Talk' started by Shaytan, Sep 23, 2018.
  1. Shaytan
    Shaytan Squier-Meister
    352
    Apr 10, 2018
    Lisbon, Portugal
    I've bought my Jackson a little over a year ago. I've noticed the high E string would sometimes slip off the fretboard, but I always assumed it was down to the fact the locking nut was mounted a bit over that side. Being lazy like I am, I decided to just wait until I changed the strings to fix that, but recently a friend of mine visited me and that was the very first issue he noticed right away.
    Worried, I decided to investigate. Placed the nut properly and even set the neck properly in the pocket. The problem was still there. But, looking more carefully, I noticed the strings sat perfectly in place both at the nut as at the last frets. Confused, I placed a straight long ruler on the side of the neck and look and behold, the neck was crooked to one side at the middle!
    Could this perhaps be fixed by tightening the truss rod? I don't have the key for it but I'll take it to the luthier when I go get my classical back from the setup and new bone nut and saddle I've ordered, I've noticed it also needs to be tightened a bit, but on the only thread I've found online about this, it seemed the neck is pretty much worth throwing in the fireplace in such a case...
    Any help and advice would be highly welcomed!
  2. Guitarmageddon
    Guitarmageddon Squier-holic
    Nothing to do with truss rod...it's neck alignment....
    If this is a bolt on neck you string it up with 6 new strings (looks like 1 is missing in your pic), tune it up like normal, and then loosen all 4 neck screws 1/4 to 1/2 a turn or so....then pull the neck into alignment so the high E and low E are the same distance from fretboard edge....then re-tighten the screws.....
    EDIT - if you say the strings are aligned at the nut AND at the neck heel area but not in the middle.....that means the neck is WARPED and shot.....no good....
  3. Triple Jim
    Feb 16, 2018
    North Central NC
    I have no idea what Jackson's warranty is, but it might be worth sending some good photos to their customer service department to see what they have to say. That much side to side warpage is pretty rare, and they might be willing to send you another neck to keep up their reputation.
  4. Shaytan
    352
    Apr 10, 2018
    Lisbon, Portugal
    Sadly I bought it used and it's a decade old, so I doubt they'd have a warranty that long LOL
    I forgot to mention this detail but that said luthier is from whom I bought it. I thought the used guitar selection were all his and so he had made sure they were all in good condition, but actually he sells them on commission and basically only markets them in his website and keeps them in the store; his actual business is more just repairing guitars. He's a very honest and friendly guy, I'm not exaggerating his store has a solid 5 star rating both on Google Maps and on Facebook, plus I've already sent two other classical guitars from the tuna for major repairs and he was super cool, great price and very well made repairs. I'll try and see whether he'd accept to buy it back or at least either accept it as rebate for another guitar or resell it for me with no commission.
    I mean, I love the guitar, wouldn't the bow be so huge and I'd just get the nut adjusted and the frets polished so that the high E wouldn't slip out of the fret so easily, but in such case I'd probably do these in order for it to be as good as possible and eventually either selling or trading it for less value and accept the loss as lesson learned to always check a guitar regardless from whom I buy it.
  5. Triple Jim
    Feb 16, 2018
    North Central NC
    You never know until you ask. Some things are so bad that a company will fix them many years after a normal warranty runs out. A sideways warp that bad should never happen. Send them good photos and ask what you can do to get this great guitar to be playable again.
    I bought used a high end bicycle seat off eBay and found it had a crack in a small plastic part that supports the top. I emailed the company and asked if I could get that small part to fix it. It was not the current model, and they didn't have the part available, so based on the photos they sent me a brand new seat.
  6. Dave M
    Dave M Squier-Meister
    294
    Feb 27, 2017
    Mira Loma, CA
    neck be bent for sure.! lots of room for the Low E !in the middle o_O
  7. Shaytan
    352
    Apr 10, 2018
    Lisbon, Portugal
    I think the photos make it look worse than it actually is, I accidentally didn't took them right in front of it, but when I get home in a couple days I'll get some better pics.
  8. Jay Jackson
    Jay Jackson Squier-Meister
    179
    Sep 1, 2018
    sanluisobispo CA (3401
    do you mean that around the 5th to 10th fret the neck actualy sag's down. and not just twisted.eather way to fix it you would need to build a straight rectangle Box Jig that could be adjusted close to put the neck in , Probly easyer to replace the neck. I have heard of using a heating Pad wrap it around the let it go under the strings put it on Low seting and its possible for the wood to return to its original shape.dont over heat it. I think it was 3 days then turn off heating pad and let cool naturaly.The person said he has done this twice to fix twisted neck
  9. DrBeGood
    If this is a bolt on neck, just reposition it.
  10. Shaytan
    352
    Apr 10, 2018
    Lisbon, Portugal
    Ah, I've actually read that thread as well, trust me I was so stocked with this I've already went through the whole web (I only haven't gone to the dark web... yet) in search for similar cases and solutions. There's also the other side of the story with tales of necks getting split along the grain and the finish burnt, so I'd rather look at all the other options (namely, either selling/trading it and compensating the problem by moving the nut to divide the issue by the two E strings and to recrown the frets so the string doesn't roll over the edges so easily) or at least seeing if the luthier at least offers to do that repair himself free of charge.
    That was the first thing I've done, I'm aware of that rather common adjustment, but with a straight ruler I've confirmed the neck is really crooked, it's not poor adjustment that is causing the problem. Thanks for the suggestion anyways.
  11. MikeyH
    MikeyH Squier-Meister
    245
    Jan 2, 2017
    Hawaii
    You're right, judging from the photos. The neck is curved laterally, not set at an angle in the pocket. Conventional truss rods can't correct that. I'd say the neck has to be replaced. What a disappointment. Hope it's still under warranty.
    Kenneth Mountain and Shaytan like this.
  12. kjmac
    kjmac Squier-Nut
    614
    Aug 14, 2017
    Omaha, NE
    I could be way off here, but in closely looking at the photos, it appears that the high E string is too far over in the nut. The Low E looks perfect but there is quite a bit more distance between the E and B strings than the rest of the strings. I guess it could be an optical illusion but I wold try to adjust the #1 E string up about a 3/32 at the nut. The neck appears to be straight from what I can see.
  13. Jay Jackson
    179
    Sep 1, 2018
    here is what could have caused this. I have seen Guitars stored for longer periods of time standing up in a position that has the guitar leaning side ways and the neck is resting on the wall so over time the neck will bend.
  14. Shaytan
    352
    Apr 10, 2018
    Lisbon, Portugal
    UPDATE: I got it back from the luthier earlier this week (I could only take it there last week) and luckily it's fine now. As I've said, I think the photos exaggerated the problem given the apparent bow wasn't even on the area where the string got closer to the fret edge. He placed in better in the neck pocket (I didn't bolted it down properly when I tried to do so, he showed me he could easily move it around even with the strings on) and shimmed it (to get good action, I'd have to lower the bridge completely) and it plays a lot smoother now.
    I'm so happy that it's fine, not only I really like the guitar and it was on my nerves during all this time, but also I feared this could hurt my relationship with the luthier, since he made great jobs on both mine and the tuna's classical guitars I've taken there (one of which had the top with a giant crack, nearly all split apart and has been playing perfectly ever since) and with bargain prices, and so I planned to pay him visits often - he not only took care of the issue, but also gave it a full check-up and a set-up (it only needed the strings lowered just a bit) for the price of just the strings, because I bought it from him. No wonder his store has a solid 5* rating and a bunch of guitars getting serviced all the time!
