Franken Squier Build
Discussion in 'Squier Stratocasters' started by Angry Possum, Jan 31, 2020.
  1. Kenneth Mountain
    Laminate hardtails are ok - a little thin maybe ? I had a few - since you have the tuners off - slap some slotted tuners on her 10.00 - they will cover most of the holes. with a pool route you can do everything ? you have a great fun project cookin ! take a lot of pics !!!!!!
    Angry Possum likes this.
  2. Angry Possum
    Angry Possum Squier-Nut
    717
    Oct 30, 2019
    Squier Town NY
    I will take pics as I go.. . I have to first design the slide assembly inside the body boat route. Thinking of using sliding draw brackets.
  3. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    I'm thinking of using this for the sliding pickup, in the boat route. I may have to alter it I suppose. Its probably way too long and too high.
  4. Kenneth Mountain
    rattle and loss of vibration - wherever the pup is - the mech holding it there must be solid / locked down - but I'm digging the concept !
    Mr Bones and Angry Possum like this.
  5. Kenneth Mountain
    rails and thumb / set crews ?
  6. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    On YT, Some guy used Legos and Lego wheels attached to the pickup somehow. I'll try and find it.
  7. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    Here it is. Whan an awesome concept.
  8. drneilmb
    drneilmb Squier-Meister
    362
    Jun 8, 2019
    Iowa, USA
    I'm a wholehearted supporter of scuff-sanding the existing finish and spraying over it. I figure that 90% of painting is surface prep and you've already got a tremendously flat, stable surface on there already.
    I'm working up to a matte black spray job for a dinged up black SE body and I've been doing some testing on some scrap pieces of an old Starcaster Mini body. The spray paint looks great over the poly and very solid adhesion. I need a better ding filler than the wood filler I tried. I think that my next attempt will be good old Bondo.
    But if you're spraying red over a black base, you're more likely to end up with CAR than Fiesta, depending on how thick you are putting on the color coats. Should be hot either way.
  9. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    Thats what i figured, and thanks for your timely advice. Question: I have never spray painted a body, i have used clear coat, but never sprayed a color paint. What paint would you recommend?
  10. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    I just Clear Coated The Franken Squier Headstock, its a little warmer here in NY, so I figured I'd do it now and get her done.
    Before and After Pics, Respectively...
  11. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    If you look closely, you can see a light fade by the headstock logo, from me sanding off the original painted Squier logo. I'm not to anal I guess, as I could of restained the headstock first, then applied the Franken Logo, and in turn clear coated it.
    Mr Bones and Kenneth Mountain like this.
  12. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    Its looking pretty cool so far... I can't wait to paint the body fiesta red. Then I'll configure the slide pickup mount into the body. Gonna be nice I'm sure.
  13. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    Perhaps, I'll utilize 1 humbucker pickup that goes into the slide mechanism, im just not sure yet. I do like single coil pickups alot, If I go single coil, I think I'll use a neck pickup for the slide. I do have a hot rails pickup which I purchased in China that has 9k ohms on one side and 4k ohms on the other. I will consider just using 1 single push pot, with no other pots or switches, kinda like the Tom Delonge setup. And also will consider a coil tap along with the push pot.
  14. DJGranite
    DJGranite Squier-holic
    Feb 7, 2012
    maine
    I am surprised and better informed.
    Thanks for sharing that.
  15. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    The Headstock is done with 2 Coats of Clear Coat.
    Looks nice.
  16. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    As we speak, I'm bidding on the Lego wheels and axels for the sliding pickup jig.
  17. Angry Possum
    717
    Oct 30, 2019
    Squier Town NY
    I'll be using an Axel and Tire combo, from a used Lego set, this will be able for me to adjust, move, slide the pickup, up and down in the body cavity for different tones.
    20200202_150325.jpg 20200202_150151.jpg 20200202_150031.jpg 20200202_150442.jpg
  18. captnsquid
    captnsquid Squier Talker
    3
    Jun 16, 2018
