Deluxe(?) tuner upgrade for Squier Bullet?
Discussion in 'Squier Stratocasters' started by yomuppet, Mar 23, 2012.
  1. yomuppet
    yomuppet Squier Talker
    45
    Mar 2, 2012
    Hey Folks,
    There have been a lot of threads recently regarding upgrading the "trapezoid" tuners, and my question is specifically regarding a Bullet with the trapezoids with the plastic sleeve... the ones on the "right" in this thread:
    http://www.squier-talk.com/forum/squier-stratocasters/3687-so-there-least-two-types-trapazoid-tuners.html
    Would these tuners below be a drop-in replacement? I'm not a big fan of the rectangular Kluson look, and really like the vintage F-stamped style. [​IMG]
    Details from the listing:
    FENDER SQUIER J-807 deluxe tuners for Strat/Tele
    Package of 6 with bolt bushings and washers, 2 pin mount.
    Fender part number 007 3867 000
    Stock on Deluxe Strat, Deluxe Hot Rail Strat, Lavigne & Whibley Teles, Affinity Strat with IC serial number
    If they will not drop in, what will be necessary, just reaming the holes a little wider? Drilling somewhere? Where?
    Thanks in advance for your comments!
    J
  2. mg2125
    mg2125 Squier Talker
    68
    Illinois, USA
    Yes, you will have to enlarge the holes. I don't believe those tuners will cover the screw holes left by the trapezoid ones you're replacing, so you will need to fill those. Finally, the new tuners have a pin to keep them from rotating, so you will need to make a hole or two for that (I write two because iirc, some of those tuners have two pins).
  3. mg2125
    68
    Illinois, USA
  4. yomuppet
    45
    Mar 2, 2012
    Those threads have a wealth of information, much better than what I got through searching. Thanks so much.
    J
Share This Page
