Bullet Strat HT HSS or Affinity Telecaster HH - first guitar
Discussion in 'Squier Stratocasters' started by tommykai0210, Jul 11, 2018.
  1. tommykai0210
    tommykai0210 New Member
    1
    Jul 11, 2018
    Bắc Ninh
    Hi everyone, I was wanting to see if y'all could offer me a few opinions:
    What is a better first guitar: Bullet Strat HT HSS or an Affinity Telecaster HH? This will be used for anything from classic rock, Johnny Cash, Metallica, ACDC, etc.
    I have ordered a VOX Pathfinder 10 for the amp.
    Thanks!
    dbrian66 and brians like this.
  2. Eddie
    Eddie Dr. Squier
    Both are great. Try them both on for size and see which one fits you better.
    Is it for you? If so, get both.
  3. TheKurdtz
    TheKurdtz Squier-holic
    Sep 13, 2017
    Holland
    does it have to be a strat? you can also go for a (used) epiphone SG, might be a better choice for the music you wanna play
    mitch_cumsteen and dbrian66 like this.
  4. horax
    horax Dr. Squier
    Aug 9, 2010
    colorado springs
    I prefer teles in general, but TheKurdtz is right....a good SG would fit the bill nicely.
    TheKurdtz and dbrian66 like this.
  5. brians
    brians Squier-Meister
    469
    Oct 1, 2017
    South Africa
    My quick portable/home player rig is Pathfinder 10 and Bullet Strat sss, been a while now and it works great for me, I've even miced that amp at jams and it's great.My suggestion is the Bullet HT if you don't want the trem, it's good to have the single coils for the Strat soul.
    Just my choice.
    Check out the options above ,but Squier is the deal for me, have others including a Ephi, but my old Bullet does it for me.
  6. brians
    469
    Oct 1, 2017
    South Africa
    duggerh, squierbilly and dbrian66 like this.
  7. kjmac
    kjmac Squier-Nut
    675
    Aug 14, 2017
    Omaha, NE
    I would go for the Affinity Tele vs the HT Strat. There is just something about a Tele. My first Squier was an Affinity Strat and it turned out to be a great mod project. However, once I got my Std. Series Tele, I was hooked. I even built my own Tele Partscaster and it is one of my favorite guitars.
    duggerh and dbrian66 like this.
  8. squierjosh
    squierjosh Squier-holic
    Apr 9, 2010
    MN
    I personally find Squier Teles to be higher quality overall than the Strats. Not sure why. More moving parts on a Strat, I guess, and since the parts are cheap...?
  9. ponca
    ponca Squier-Meister
    134
    Oct 13, 2014
    Pennsylvania
    Get whichever one looks and feels cooler to you. Genuinely, the most important thing about a first guitar (as long as you clear a certain quality baseline, which all Squiers do) is that the vibe really makes you want to pick it up and play it.
    mbroadus, squierbilly and dbrian66 like this.
  10. jjudas
    jjudas Squier-holic
    Mar 23, 2016
    Metro New Orleans
    I like Strats and Teles. I would go play both and see what you like better before you order one.
  11. dbrian66
    Like others have said, if you have the opportunity, go play both and see which one you like better.
    As far as my opinion on which one of those is a better first guitar, I would go with the bullet. Both are hard tails which is great for a first guitar, but the bullet has a more wide range of tones because of the pick up configuration. You don’t know yet if your a single coil guy or a humbucker type of guy. With the bullet you can play around with all the different pickups and see what you like and use that info to buy your second guitar.
    Good luck and welcome to the best forum on the internet.
    mitch_cumsteen likes this.
  12. brians
    469
    Oct 1, 2017
    South Africa
    I second that, this is a really down to earth , friendly forum without any snobbery or BS that I have come across, and I'm on a few , for a longish time, well said
    duggerh likes this.
  13. bgmacaw
    bgmacaw Squier-Nut
    687
    Jan 19, 2018
    GA USA
    I'd go for the Tele myself. I'm just not a big fan of the HSS Strat configuration, preferring either SSS or HH. But, it's really down to which you like the best. Both are equal in terms of build quality from what I've observed.
    On the Epiphone SGs in the same price range, I've found the to be lower quality than comparable Squiers. These problems aren't difficult to deal with if you know what you're doing but could discourage a beginner. More expensive Epiphones measure up better though.
  14. squierjosh
    Apr 9, 2010
    MN
    General rule I've heard on Epipone SGs is to stay away from the bolt on models. But it seems like the Special II bolt ons are just fine. Not sure why the hate for the SGs.
  15. bgmacaw
    bgmacaw Squier-Nut
    687
    Jan 19, 2018
    GA USA
    I have a SG Special and a LP Jr and I've worked on a few other Epiphones for friends and acquaintances. The nut and the fret work are the main problem areas. I had to replace the nut on my SG and almost all I've worked on needed fret leveling and sprout smoothing, more than on any Squier I've seen in recent years.
    The tuners are covered gear style that will hold tune OK if you know how to loop and lock string good but are a problem for newer players.
    Pickups on the SG are very hot ceramic pickups that are lacking. An inexpensive high output ceramic like the Guitar Madness Dark Matter is a great improvement if you want that kind of tone. I have a set of GM Alnico 2's that do a very good vintage sound on mine. The stock P90 on the Jr is perfect though.
    squierjosh likes this.
  16. newscaster
    newscaster Squier Talker
    49
    Aug 23, 2018
    Nevada
    I really like this one, with a couple of humbuckers you can rock it hard, and even dial
    it back to something jazzy, but I'm hooked on Affinity right now.
    brians and burke like this.
  17. mitch_cumsteen
    mitch_cumsteen Squier-Meister
    150
    Jun 25, 2018
    Planet, Idaho
    I'm a new guitarist also and one thing that I noticed about my HSS Affinity was the nut width of 40mm (1.65") as compared to 42mm (1.65") in most other Squier models. I didn't think the narrower neck would be that big of a deal, I mean it's only 2mm, so how can it be that noticeable. But I did notice it...immediately. I think it's because, as beginners, our technique is a little sloppier and also we play a lot more open chords in the first position (the first three frets) which is the narrowest part of the neck. I had a tough time not muting the adjacent strings when forming chords. I swapped necks on the guitar to a 42mm from a Squier SE and it's great now.
    Like others have said, if you have a local guitar shop, try a few different brands and models.
