Affinity Strat Glued piece of wood in neck pocket
Discussion in 'Squier Stratocasters' started by marsbleu, Jan 7, 2019.
  1. marsbleu
    marsbleu Squier Talker
    12
    Jan 7, 2019
    Greece
    Hello there,
    New here in the forum and in the sport of modding.
    So i noticed piece of wood glued on the side of the neck pocket which got me a little bit worried.I thought that that the neck pocket was wider than the neck so they glued the piece of wood to make a "tight" fit.
    Am I right about this?Is there a way to fix this or should i not worry about it?
    Thank you in advance and i hope i will be staying here for while.
    duggerh and VealCutlet like this.
  2. DrBeGood
    If the neck is stable and plays well, act like you've never seen it and play the hell out of that Strat.
    PURPLE HAZE !
    ... no it's white ...
    whatever, turn it to 11 !
    fattboyzz, marsbleu and Eddie like this.
  3. Eddie
    Eddie Dr. Squier
    It's a shim. Sometimes there are minor adjustments needed. Even $5000 MIA Strats have them.
    fattboyzz, DougMen and marsbleu like this.
  4. marsbleu
    12
    Jan 7, 2019
    Greece
    Thank you both for the reply.I will try doing the acting part.
    First day here and I already feel enlightened :).
    Cheers
  5. Eddie
    Eddie Dr. Squier
    Welcome. Hope you stick around awhile. This is a good place. Lots of information. :)
  6. Welcome to Squier Talk … let's see that Stratocaster … pics?
  7. marsbleu
    12
    Jan 7, 2019
    Greece
    Well it's a work in progress ...or a work in pieces still.But here she is.Sorry for the pic it lacks of artistic flare.I have changed the wiring,pots and switch and added a Suhr humbucker,later on i will add two single coils and see how it sounds since the pots are 250k.I sanded the neck a bit and it feels nice.I will change the bridge and tuning machines.Baby steps....the tough thing will be to setup the instrument once it is assembled.First timer here.
    Shaytan and Eddie like this.
  8. jefffam
    jefffam Dr. Squier
    Jan 26, 2015
    Portland, TN
    Hi and welcome to Squier-Talk!
    There's lots of information available here for just about any mod you might want to do. There's also several threads about doing setup. Some may direct you to a specific YouTube vid or another site, but rest assured the links have been researched by the poster so most all contain good, valuable information.
    Enjoy yourself and have fun!
    marsbleu, SquierTap and Eddie like this.
  9. strat_strummer
    strat_strummer Squier-Nut
    760
    Nov 24, 2018
    Lost in my Sticks
  10. AngelDeVille
    AngelDeVille Squier-Nut
    712
    Jan 29, 2017
    ABQ
    Love that color!
    Welcome!
    marsbleu and SquierTap like this.
  11. SquierTap
    SquierTap Squier-holic
    Jul 14, 2018
    Nashville, Tn
    Welcome aboard, man... Boy, did you come to the right place! Lol... You'll find us SquierNuts are WAY more laid back and helpful than some forums... And don't sweat the setup... I've said it ALOT before, lol, but when I got here 9 months ago, I couldn't even change strings, now I've completely re-built my own custom guitars including finishes and wiring... Stick around, hoss... And that Strat is gonna be a screamer and a looker when ya get her done...
    Eddie and marsbleu like this.
  12. marsbleu
    12
    Jan 7, 2019
    Greece
    Big thanks to all of you.You're most kind and most helpfull.I am really enjoying the process and it's an additional pleasure to be in squier-talk.
    Thanks again :)
    Eddie likes this.
  13. Loin Lover
    Loin Lover Squier-Nut
    937
    Jul 26, 2018
    Backwoods, USA
    Welcome to ST.
  14. SpeedKing
    SpeedKing Squier-holic
    Apr 9, 2015
    And another Welcome. Friendly helpful folks here and I hope you'll think so too.
    Nice skills so far and that's a good looking strat. What are your plans for bridge/block and tuners?
    If bridge/block and it's the thinner body Affinity you can buy shallower but otherwise full size blocks for them now but be careful it'll match the bridge plate you use. The other common perhaps easier option is to use the full depth Fender MIM standard strat unit (the entire 'unit' comes with block, bridge plate and Fender stamped bent steel saddles all much better quality than the Affinity's) and either leave the rear plastic trem cover off, move it out from the body a few mm with foam etc or have the new block milled down a few mm (which I did). All options have been tried here successfully.
    marsbleu likes this.
  15. duggerh
    duggerh Squier-Meister
    186
    Jun 1, 2018
    Pacific Northwest
    Welcome
  16. marsbleu
    12
    Jan 7, 2019
    Greece
    Good day to all.Thanks for your kind words.
    Concerning the bridge and tuning machines, I haven't come to a decision yet.What i am looking for though is to avoid drilling for now and for components to be black.I am thinking about the wilkinsonVSVG if i can find it or the Babicz FCH concerning the bridge.Bare in mind that the measurements i made are completely rough and its very possible that they're off (almost certain).As to tuning machines i am thinking Graph tech lock ratio.
    Any feedback/advice/correction would be most welcome.
    Ps If i have neglected doing something regarding the rules or of the forum pls feel free.
    Cheers
  17. archetype
    archetype Squier-Nut
    602
    Oct 24, 2017
    Williamsville, NY USA
    I wouldn't worry at all about a wood shim glued into the neck pocket. My Squier Affinity Strat came from the factory with automotive body putty in the side of the neck pocket to salvage some bad routing. The finished guitar looks perfect and works fine.
  18. fattboyzz
    I use whatever pick is the correct thickness for the shim . :0)
  19. Shaytan
    Shaytan Squier-Meister
    421
    Apr 10, 2018
    Lisbon, Portugal
    Hey there, and welcome! Out of curiosity, that body was bought new or second-hand? I'm curious whether someone in the factory went over it or if it was more likely a tech that used that to fix the excess of neck weegly in the pocket.
    Do keep us updated on that project of yours! It sounds really nice and you'll surely notice most of us have a thing for modding and customising guitars! :)
  20. marsbleu
    12
    Jan 7, 2019
    Greece
    Greeting to all
    Shaytan, the guitar is brand new affinity.
    Do I upload updates in this thread or create a new one?
    Have a nice one and thanks again for the warm welcome.
