2001 Indonesian Standard ?
Discussion in 'Squier Stratocasters' started by ghostwolf, May 10, 2011.
  1. ghostwolf
    ghostwolf Super Moderator Staff Member
    1,237
    Dec 30, 2009
    texas
    Admin Post
    i need some advice on a std. Squier strat. it's a 2001, made in Indonesia. all the parts appear to be original, bought used from GC. when i got it, the headstock decal had been sanded off, nothing remaining but "made in Indonesia' on the back of the headstock. large headstock, 22 frets, decent sealed tuners, black plastic insert in the truss adjustment hole, rosewood fingerboard. the neck appears to be original, no plugged & re-drilled mounting holes. the only anomaly is the width at the nut, it appears to be the size of an affinity instead of the full size standard. did the specs for this model change since 2001, or have i got a standard from a parrallel niverse?
  2. mkgearhead
    mkgearhead Squier-holic
    2,352
    Dec 18, 2009
    Fort Morgan, CO
    My '01 Shoreline Gold Standard had the narrow nut, too. I'm not sure what other years did.
  3. Cool Craig
    Cool Craig Squier-Meister
    215
    Mar 8, 2011
    Darien, IL.
    if you take off the neck, the body "should" have a crude description of the serial number. my 03 IC Affinity body has a paint knock-out that states IC-NOV-03 where the neck bolts to the body. This may help determine if the serial on the neck corrsponds with the body....and that its not obvious that the body has a different neck. I assume you are measuring a 40mm nut and comparing to a 42mm std nut??
  4. Cool Craig
    215
    Mar 8, 2011
    Darien, IL.
    can ya take the neck off easily at this time?? does the body have a date code that corresponds with the SN on the headstock?? IE: IC-XXX-01
    Im tryin to find a great Squier buildsheet reference that I came across yesterday that if I find it, Ill post the linkee.
  5. Kid Klash
    Kid Klash Squier-holic
    1,758
    Dec 17, 2009
    PDX
    Yes - the neck on the Indonesian Standard Strats changed between 1999 and 2000, from the wider (42mm) chunkier neck to the narrower (40-41mm) thinner neck. My 1999 Double Fat Standard (in the pics below) has a wide, chunky neck.
  6. dman
    dman Squier-Nut
    953
    Antioch, IL
    It also changed on the Standard Tele's from 2000 to (I believe) 2003, then it changed back to 42mm. I have a 2002 20th anniversary Squier Standard Tele and it has a 40mm neck width. The good news is that there is enough room to replace the 32mm E-E nut with something wider. I got a GFS 42mm bone nut, which has a 33.6mm E-E spacing... a considerable difference. It still takes a bit of getting used to, but with the wider spacing the neck's very playable.
    Heck, according to Dan Erlewine's "Guitar Player Repair Guide", Albert Collins' Tele had a 39.3mm wide neck with a 33mm E-E spacing...didn't hurt his playing any!
  7. Kid Klash
    1,758
    Dec 17, 2009
    PDX
    Interesting.
    Personally, I have no problem with the 40mm wide nut necks. One of my favorite Strats (photo below) has the narrow neck and string spacing.
Share This Page
