09-06-2010, 04:16 AM
#1 (permalink)
New Member
standard strat tremolo replacement
Hi, I'm new here and am loving it! I'm looking to buy a squier standard strat locally but the sellers tells me that the 2 point tremolo is damaged after a fall. (basically the original trem arm or replacement arms won't fit in anymore). After reading up on the problem it seems the stud spacing of the 2 point trem isn't a standard width and is approximately 63mm. Can anyone confirm this?
I haven't been able to find any replacements of the same dimensions though. Has anyone ever done this without redrillling for the studs? If there is no other option I'd like to order a new bridge from squier. Would this be done directly through squier or a local dealer?
Sorry for the mass of questions!
Thanks in advance
Sponsored Ads
Posts: N/A
Sponsored by...
09-06-2010, 08:53 AM
#2 (permalink)
Try Guitar Fetish i would bet thay will have something that will work.
My long hair don't cover up my redneck !
09-06-2010, 12:53 PM
#3 (permalink)
gfs doesn't have a replacement for a standard. word on the street is that the standards have a slightly different bridge spacing. i believe this is the replacement/upgrade: http://www.killerguitarcomponents.co...mart&Itemid=53
anyone else know about this?
Axes: Meg's Marmanocaster (formally a Squier SE), Epi Les Paul Standard, Partscaster, Fender Acoustic, '69 Teisco E-110 Tulip, '11 Squier Bullet, '11 Squier Cyclone
Amps: Mustang I, Danelectro Honeytone
Mod the livin' crap out of it!!
09-06-2010, 01:54 PM
#5 (permalink)
And no, Guitar Fetish has nothing. No company makes a Squier 2 point replacement except Squier and Jackson which is the same company , same parts.
And a new one costs approximately $89 if they have to order it.
09-06-2010, 01:57 PM
#6 (permalink)
http://cgi.ebay.com/GUITAR-PARTS-LOT...#ht_1237wt_932
Heres a set in black with pickups and backplate.
I would check if this is the same spacing though because it's a 1987 so it may be different . It looks slightly different
09-06-2010, 02:55 PM
#7 (permalink)
New Member
Thanks for all the help guys. I didn't realise the jackson had the same tremolo, I'll have a look online to see if I can find any in the UK. Cheers.
09-06-2010, 08:14 PM
#8 (permalink)
this isnt? http://www.killerguitarcomponents.co...hk=1&Itemid=53
09-06-2010, 08:18 PM
#9 (permalink)
That is a replacement block and not the whole bridge assembly. I actually have that block and yes, it's killer. They do not make the bridge plate yet, only the block.
01-13-2012, 08:20 AM
#10 (permalink)
New Member
i don't know how to post
I want to replace my one-way tremelo for a floating one on a fender squire affinity strat bought in 2011.
01-13-2012, 09:19 AM
#11 (permalink)
Quote:
You don't need to replace anything, all you need to do is adjust the spring tenson. There are ton of videos on you-tube that show how to do this.
Oh.. and welcome to the forum!
| Thread Tools |
Search this Thread |
» Random Photos |
» Sponsored Links |
