09-05-2010, 01:29 PM
#1 (permalink)
another typical set up question
ok, so i've got the relief in the neck, and the bridge saddles jacked has high as they'll go. now the action is high, but if i drop the saddles any lower, i get fret buzz from fret 9 on up. i put a shim in the neck and that helped a bit but still not as much as i wanted. what can i do next before i break down and take it to a tech?
Axes: Meg's Marmanocaster (formally a Squier SE), Epi Les Paul Standard, Partscaster, Fender Acoustic, '69 Teisco E-110 Tulip, '11 Squier Bullet, '11 Squier Cyclone
Amps: Mustang I, Danelectro Honeytone
Mod the livin' crap out of it!!
Sponsored Ads
Posts: N/A
Sponsored by...
09-05-2010, 02:55 PM
#2 (permalink)
Moderator
how much relief is there in the neck? is it safe to assume you shimmed the neck at the headstock end?
09-05-2010, 03:49 PM
#3 (permalink)
If the frets are properly leveled and the neck is properly adjusted You shouldn't get fret buzz..That's where you should start..
09-05-2010, 03:51 PM
#4 (permalink)
my guess is too much relief in the neck. get the baby almost flat!
09-05-2010, 07:00 PM
#5 (permalink)
as well as above posts, get a small straight edge that will span three frets ( I use my stew mac set up gauge), work up and down the neck, if it rocks at all you have a high fret and will def cause buzz.
09-05-2010, 10:19 PM
#6 (permalink)
Need a fret leveling and recrown. or more shim. Choices....
09-05-2010, 11:14 PM
#7 (permalink)
frets are level. i'm going to try pesky's advice now and tighten the truss rod. i'll keep u guys posted. thanx!
09-06-2010, 12:41 AM
#8 (permalink)
making progress. i tightened the truss rod...quite a bit actually. about 3/4 of turn! the neck still looks like it's gotta slight curve to it, but i'll give it a couple of days to settle. in the meantime, i was able to lower the saddles a hair. when i stuck my gauge up to the strings and the 17th fret, action was reading at 4/64"...fender specs. the actions feeling better now so that's all that matters. we'll see in a couple of days how the neck straightens out.
| Thread Tools |
Search this Thread |
» Random Photos |
» Sponsored Links |
