Forgot Password? Join Us!
Notices
Reply
Old 04-29-2011, 11:03 PM   #1 (permalink)
Default Which Strat has a full size body ?
Hi there, was just curious, which Squier Strats have full size strat bodies in their current line up ? Do the bullets or affinities ? Or is it VM and CV that only have the full size body.
SpitfireCWII is offline   Reply With Quote
Old 04-29-2011, 11:28 PM   #2 (permalink)
spanker63's Avatar
Default
The SE has a full size body. The one I have has a pretty nice neck as well. You can find them pretty cheap on craig's list or guitar center used.
soundcloud Youtube
Fuse Presets
spanker63 is online now   Reply With Quote
Old 04-29-2011, 11:29 PM   #3 (permalink)
pictoratus's Avatar
Default
Bullets and Affinities have smaller (thinner) bodies, although not sure about the older ones.
The higher end Squiers have full size bodies, along with the SE (Special Edition)
The Single Coil
pictoratus is offline   Reply With Quote
Sponsored Links   #
Sponsored posting
Old 04-30-2011, 12:05 AM   #4 (permalink)
squierHSSfan's Avatar
Default
I'm not noticing a whole lot of difference in the bodies between my Bullet and Standard....the Bullet body should be thinner, right?
-'01 Fender MIM J-Bass
-'02 Squier Affinity P-Bass
-'09 Squier Bullet Strat
-'11 Squier Standard Strat HSS
squierHSSfan is offline   Reply With Quote
Old 04-30-2011, 01:59 AM   #5 (permalink)
Default
I have an Obey Graphic Stratocaster Collage (Headstock say Standard) And then i have an American Special Stratocaster HSS Sunburst.. and both are the same contour body, weight, and 70s headstock... i swear
tecladista is offline   Reply With Quote
Old 04-30-2011, 02:20 AM   #6 (permalink)
Sparkfire's Avatar
Default
Measure the body. If the thickness at the horn is 1.75 inches then it is a full size body. Most bullets and Affinities are below that. The cheapest full size body you will find is the SE. The SE is part of a strat-pac which comes with the little cheap 10 watt Squier Amp. Wonderful full size for modding. Anything that says "standard" on the headstock is full size. The SE doesn't say SE on the headstock, you just have to measure it. The Deluxe is full size but it doesn't have Deluxe written on it either. Measure is the only way to know for sure. People can make up a waterslide so just depend on your rule or a caliper. Real reason you need the full thickness is so the guitar will accept a full size tremolo block. If the body isn't full size the bottom of the block will stand out the back of the body. I have a bullet hardtail and it is only 1.50 thick. That is 1/4 thinner than my Deluxe. Also 3 1/2 pounds lighter. I love both of them but my bullet is a lot easier on my shoulder. Of course, the Deluxe is a lot more expensive and side by side it is easy to see why. Everything today is top quality as far as I can tell. Just measure it! Hope my rambling helped.
"Ain't it great to be alive and be in Tennessee."
Charlie Daniels
Sparkfire is offline   Reply With Quote
Old 04-30-2011, 02:56 AM   #7 (permalink)
Default
Quote:
Bullets w/trem are normally around 1-5/8" (41mm) where the SE, Standard, Deluxe, VM and CV are all normally 1-3/4" (44.5mm). The Affinity and the pre-2008 hard tail Bullet are 1-1/2" (38mm).
softwarejanitor is offline   Reply With Quote
Old 01-27-2013, 01:32 PM   #8 (permalink)
Default
I was thrown for a loop a little bit by a post in another thread, which suggested that "some" SE's are not full size. Has anyone ever encountered an SE that was NOT 1.75" thick?
I recently got an SE to do a bunch of mods on, because I had done a mod on a 1996 MIC Squier Bullet, but chose not to do a GFS steel trem block because I had heard that Bullets and Affinitys are smaller.
Interestingly enough, I just grabbed a ruler and measured the SE, and it does look to be exactly 1.75" at the thickest parts (curve where it rests on your leg, etc.). Interestingly enough, the '96 Bullet is also the same 1.75". Again, this is not with a caliper, so it's not exact. But they look to be the same. They are shaped differently in other areas (such as where it tapers inward near the armpit), and the SE does feel "heavier", but that could be due to the type of wood (agathis?) or the thicker neck.
I've certainly picked up Affinity Squiers at Guitar Center that were dramatically thinner than either of my two Squiers, so I know there are thinner Squiers. But is it possible to have a full-size Bullet? And is there a such thing as a non-full-size SE?
Thanks, I have a GFS trem with full steel block coming in a week or so, so I'll be trying it out and just making the best out of however it turns out.
StormJH1 is offline   Reply With Quote
Old 01-27-2013, 02:22 PM   #9 (permalink)
Default
Any SE model from any year I've seen is full size. There are some bullets as well as affinities from earlier years that are full size. I don't have the exact models or years, country of origins etc. but I'm sure people on this forum can help with that.
mikm is offline   Reply With Quote
Old 01-27-2013, 09:52 PM   #10 (permalink)
Default
Quote:
That's pretty much what I thought, word for word. I would not have been surprised if the Bullet was less than full-size, but it may be. SE's, which is the one that comes in the box set with the crappy amp, were always full-size, or so I thought. Of course, that doesn't necessarily mean all Strat components will fit on there. I'll just have to wait and see, and probably do some routing/sanding.
For example, I gutted the thing today and was not-so-pleased to find that it has something like a H-S-S cutout instead of the "swimming pool" I had on my Bullet:
I'm installing H-H pickups, so I'm almost certainly going to have to lose some of that wood that just out. Not the end of the world - it should be pretty easy to get in there with a Dremel and sand away.
Will the GFS trem block fit? Who knows until I try, but having removed the old one, it's pretty large on its own (though made out of crappy pot metal), and there were a few centimeters left in there to spare below the trem cover:
Old 01-27-2013, 11:24 PM   #11 (permalink)
Tectonix's Avatar
Default
I'm glad to know what the initials SE stand for. Is there any way to differentiate down the road if a full size Strat was from a Strat-pack or a guitar that was purchased originally as a stand alone?
Tectonix is offline   Reply With Quote
Old 01-27-2013, 11:28 PM   #12 (permalink)
1935streetrod's Avatar
Default
...Special Edition?...
"God, Love and Rock & Roll"....
Teegarden & Van Winkle
1935streetrod is offline   Reply With Quote
Old 01-28-2013, 10:59 AM   #13 (permalink)
Default
Tectonix; To help narrow down your question, A SE will have the smaller headstock than a Squier Standard. However there is always the Squier Deluxe but that will have a 22 fret neck, (so does the Standard). Now the CV will have full size body and 21 fret neck like the SE. It just goes on and on with generalizing and different model exceptions! StormJH1; The GFS trem should fit the SE size wize, I'm not sure about the screw holes lining up.
Old 01-28-2013, 05:54 PM   #14 (permalink)
Default
I've never seen an SE that wasn't 1-3/4" +/- basically finish thickness.
Old 01-28-2013, 07:29 PM   #15 (permalink)
Default
Yes softwarejanitor; Me to. I don't think I've ever seen a SE that was less than 1.75". Being what I consider to be full size in body thickness for a strat.
Reply
Bookmarks
Search this Thread:
Advanced Search
BB code is On
Smilies are On
[IMG] code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Similar Threads
Wanted: full size squier body boytcam Misc. For Sale, Trade or Wanted 0 02-25-2011 02:00 AM
Double-checking tremolo size for VM Strat upgrade squierjosh Squier Stratocasters 9 02-16-2011 08:18 AM
Would a CV Strat neck fit a Fender MIM Strat body? blingdogg Squier Stratocasters 1 11-25-2010 09:29 AM
Question: CV 50's Strat neck size Strat-toter Squier Stratocasters 1 09-04-2010 08:38 PM
"vintage" size bridge for Squier Bullet Strat? rlyacht Squier Stratocasters 6 05-05-2010 04:04 PM
» Random Photos
My Stuff
shrekfingers
My Stuff
» Recent Threads
Title, Username, & Date
Ken Rose Pickups
rlh5599
Today 01:45 AM
Affinity Strat with...
FireMaster64
Today 12:47 AM
Difference in Capacitors
jefffam
Yesterday 07:32 PM
NGD!! 2000 Standard Strat
rlh5599
Today 01:30 AM
Count to 1,000
Rhitosparsh
06-26-2013 06:40 AM
How many Lake Placid...
Gmountain
Yesterday 11:42 PM
Filling dowel holes with...
Michael7
Today 12:18 AM
Any Ukulele players here?
bdbrown
04-24-2015 07:35 PM
Saturday Project...
Caddy
Yesterday 09:56 PM
NGD - SX LP Special copy
PunKkitty
Yesterday 08:33 PM
© 2009 -2015 All rights reserved.
