Forgot Password? Join Us!
Notices
Reply
Old 10-11-2010, 08:26 AM   #1 (permalink)
markmcconachie's Avatar
Default Identifying a Squire body
I got a squire body that I am going to use for the basis of a new project...
Is there any way to identify where it was made etc?
markmcconachie is offline   Reply With Quote
Old 10-11-2010, 08:30 AM   #2 (permalink)
asquier's Avatar
Default
The serial number would help a lot. Pictures would also help.
Adam Squier
Dublin, Ohio, USA
asquier is offline   Reply With Quote
Old 10-11-2010, 08:39 AM   #3 (permalink)
Default
Where is the serial number on the body? The only writing is in neck pocket and it says Nov 1996...
The picture is from the eBay auction when I bought the body. I will take more pics if they would help.
Identifying a Squire body-screen-shot-2010-10-09-20-45-19-jpg
Sponsored Links   #
Sponsored posting
Old 10-11-2010, 09:09 AM   #4 (permalink)
Default
For what it is worth, the body seems fullsize and appears to be alder...
Old 10-11-2010, 09:18 AM   #5 (permalink)
Robbmonster's Avatar
Default
No black shielding paint... Do you know if the body has been refinned?
At a glance - and this is based on me figuring out what it is NOT - I would say it may be a vintage modified.
It seems the wrong kind of red for a Bullet or an Affinity, and it's definitely not a CV or a Deluxe (if the finish is original).
Vintage Modified is my guess, or perhaps a Standard, but other might know better.
Your business advertised here... Ask me how!
Robbmonster is offline   Reply With Quote
Old 10-11-2010, 09:28 AM   #6 (permalink)
Default
It doesn't appear to be refinished, what are the telltale signs?
The paint looks a lot less bright in real life, except under the scratch plate, here it is pretty bright which would make sense for a 14 year old body
I thought that the Vintage Modified were new? (2007 or something)
Old 10-11-2010, 09:30 AM   #7 (permalink)
Default
The auction said it was from a "Korean fiesta red HSS strat"
but I never really trust what ebay auctions say :P
Old 10-11-2010, 12:34 PM   #8 (permalink)
jimbojo's Avatar
Default
Not a Standard, look at the trem holes, a Standard would have two large not the six. I havn't seen a route like that in any of the Squiers I've opened up (Standard, SE, Affinity, 90's MIK, MIM Squier Series) But there have been so many different mfg's.
'99 Std Indo Telecaster
'89ish MIK E series Stratocaster
'95 MIM Fender Squier Series
Tele Style Parts Caster
jimbojo is offline   Reply With Quote
Old 10-11-2010, 01:11 PM   #9 (permalink)
Default
Maybe it is not a squire body?
Actually, on ebay there are many squire bodies from this period with this route... hmm
Old 10-11-2010, 01:19 PM   #10 (permalink)
jimbojo's Avatar
Default
What is the thickness? the upper arm cut looks more like those on a thin body than on a full size. It may be from an Affinity or a Bullet.
Old 10-11-2010, 01:20 PM   #11 (permalink)
Default
I just measured and it is ~44mm maybe 45
Old 10-11-2010, 01:35 PM   #12 (permalink)
Default
Not that I think it helps BUT it weights, 2.163kg (4.77080335 lbs)
EDIT:
The outer screws on the bridge are 54mm apart
Old 10-11-2010, 01:52 PM   #13 (permalink)
Default
If it's Fiesta Red, it may be a Bullet, but I always think of Fiesta Red as having a more 'powdery' look to it.
I didn't realize that, I'm not overly familiar with the Standard series :-)
Old 10-11-2010, 01:57 PM   #14 (permalink)
jimbojo's Avatar
Default
Quote:
The current models with slim bodies are something like 42mm, that means full size is some thing like 49mm, it could be something from Korea, there were some I have seen that were almost full thickness, but just a hair shy.
Old 10-11-2010, 02:03 PM   #15 (permalink)
Kyri's Avatar
Default
I had a strat body that looked the same as yours. It was from a chinese squier affinity from 1996 which I sanded to the wood and found it had a ply front and back covering about 6 strips of alder. I sanded through the ply and then used the body for an experiment. You can see some pictures here:
http://www.strat-talk.com/forum/stra...c-attempt.html
These days, affinity bodies are thinner, and if its a solid body they are usually of a similar construction (alder strips with a thin ply front and back).
The sunburst affinities often have the most beautiful grain and solid wood, (no ply front and back) with less strips, usually 3 pieces.
In any case your body looks good should be a good basis for a project. What are you planning to do with it?
Kyri is offline   Reply With Quote
Old 10-11-2010, 02:11 PM   #16 (permalink)
Beach Bum Scott's Avatar
Default
Quote:
Not quite true.
It was in May of 2000 that Squier Standards went to the 2 hole trem, and even then it must have been toward the end of the month.
My Indo 05/2000 is one of the 6 hole Standards.
I have seen several of the 6 hole Standars in the wild and member Suek also has a 6 hole Standard.
http://www.squier-talk.com/forum/squ...-standard.html
Beach Bum Scott is offline   Reply With Quote
Old 10-11-2010, 02:11 PM   #17 (permalink)
jimbojo's Avatar
Default
looks like you may have found a match, I agree on Afinity, the ones I have messed with where Indo, so the routing in the Chinese looks like yours.
Old 10-11-2010, 02:13 PM   #18 (permalink)
Default
I got a neck on ebay too.
It has had the decals removed and has not arrived yet, it too is squier... with maple board, no skunk stripe and a small headstock... Again, no idea which model it is from...
It has a fender decal which I actually want to remove, I like the idea of a custom guitar with no name
If this neck is junk, then I will look for another one...
I plan to add a tortoise shell or black pickguard, some vintage pickups (or maybe HSS) and some decent gold hardware...
How do I buy a pickguard that will fit this guitar? It has 8 holes... I would happily drill more...
Old 10-11-2010, 02:20 PM   #19 (permalink)
Kyri's Avatar
Default
Any pictures of the neck? sounds good
As for pickguards you could get almost any of them to fit. It may need new holes but that is ok as they would be covered up. The only hole you might have a problem with is the one nearest the jack plug, if you use an 11 hole guard. Then again it might be OK. I had to make a small wooden block to attach that particular screw on mine, the original squier guard must have been marginally smaller.
Old 10-11-2010, 02:24 PM   #20 (permalink)
Default
I will take some pics of everything when the neck arrives...
I do have a spare pickguard, an 11 hole and you are right, the screw nearest the jack socket doesn't quite fit... will this be the case with all the 11 hole guards? Should I just stick with an 8?
I looked at your other thread (with the similar body) it looked great, a nice relic
EDIT:
All the info about the neck
Neck: Maple
Fretboard: Maple
Inlay: Black Dot
Side dots: Black
Scale Length: 25 1/2"
Nut Width: 43mm
Heel Width: 57mm
Frets: 21
Tuner Hole Size: 11/32" (10mm)
Truss Rod Adjustment: Headstock
Once I take off the stupid decal, I think that I will like this neck
Identifying a Squire body-screen-shot-2010-10-11-19-22-13-jpg
Reply
Bookmarks
Search this Thread:
Advanced Search
BB code is On
Smilies are On
[IMG] code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Similar Threads
Help Identifying a Squier Strat IAmFunkmeister Squier Stratocasters 5 12-11-2010 07:56 PM
Help identifying horax Squier Stratocasters 1 08-13-2010 08:29 PM
Help identifying wood Strat body 1935streetrod Squier Stratocasters 6 06-13-2010 03:59 PM
Help identifying body ncjeepinyj V.C.'s Parlor 11 06-08-2010 08:24 AM
Help Identifying SquierContemporary HM E9xxx D.Allen Squier Stratocasters 1 01-10-2010 09:26 PM
» Random Photos
Maxoom`s guitars
maxoom
Maxoom`s guitars
» Recent Threads
Title, Username, & Date
Two super fine...
squierbilly
Yesterday 02:09 PM
Do you have an acoustic?
Ishmann
Yesterday 10:46 AM
VM Telecaster Custom &...
Turner_99
Yesterday 06:04 PM
Got to Meet Squierbilly...
duceditor
Yesterday 11:20 AM
NGD on the way!
guitar guy
07-24-2015 12:12 PM
For Sale Lots of Stuff: Parts,...
Son of Timett
Yesterday 09:14 PM
Having had a Vintage...
SQUIER4LYFE
Yesterday 10:15 AM
Handy Bit of Info...
rlh5599
Today 01:59 AM
Hallo I love Squiers yes.
SQUIER4LYFE
Yesterday 08:50 AM
No playing for awhile
Hammer 4
Yesterday 02:37 AM
© 2009 -2015 All rights reserved.
