Notices
Reply
Old 08-16-2010, 08:36 AM   #1 (permalink)
Default GFS block for CV 50 Stratocaster???
Hello boys regards from Spain¡¡¡My doubt is this:
I want to put a GFS trem block to my Squier CV 50 Stratocaster,but not which is the correct GFS block trem that I must buy....Who is the suitable block ... " made in mexico " GFS trem block or the "import" GFS trem block???Which is the correct measure for the Squier CV ...?I use enough the trem arm...The music that I play is a surf music and blues...Which is better for the music that i play .... the brass block or the steel block?Does someone differ in the sound?Please .... I am grateful to you very much for your help since I want to buy the trem block in the major possible briefness and not which is the suitable one...
Regards from Spain and thank you very much for your help¡¡¡
Mario.
fuzzmariachi is offline   Reply With Quote
Sponsored Ads   #
Sponsored posting
Posts: N/A
Sponsored by...
Google is online
Old 08-16-2010, 10:16 AM   #2 (permalink)
TwoMartinMan's Avatar
Default
I suggest buying the whole trem/bridge assembly, GFS part # D45 (with steel block).
That way you will be certain that the block will fit the bridge plate, and you will get a new trem arm that will fit the block (your old trem arm will not fit the GFS block). Also, the saddles in the D45 kit are an upgrade to the stock saddles.
Squier CV50s Strat, Sunburst
Squier Affinity Strat, purple, modded
TwoMartinMan is offline   Reply With Quote
Old 08-16-2010, 11:03 AM   #3 (permalink)
Strat-toter's Avatar
Default
What he said^^ I ordered the same for my CV 60's
Strat-toter is offline   Reply With Quote
Old 08-16-2010, 11:14 AM   #4 (permalink)
EGrier's Avatar
Default
Was this a direct drop in? Also, is the arm tip a close enough match to the pup covers and knobs that you don't have to replace that?
EGrier is offline   Reply With Quote
Old 08-16-2010, 11:21 AM   #5 (permalink)
Default
Quote:
Yes, the unit was a direct drop in.
However, the 6 mounting screws that come with the GFS unit are a little thicker in diameter than the stock screws. I re-used the stock screws because I did not want to make wider holes in my wood.
The arm tip is white on the GFS arm. The stock CV 50s tip is aged white. So they are not an exact match. You might be able to fit a replacement tip on the GFS arm or buy any other 10/32 screw thread arm that has the color tip you want. GFS has their #D51 arm with a cream tip that will fit. I don't know if the cream tip is an exact match to the stock CV 50s color, but it will be closer than stark white. (I just took a look at the GFS website. It shows the D51 trem arm's availability as "Not for Sale" at the moment. I'm not sure if that is the same as "Out of Stock" or if that means something different.)
Old 08-16-2010, 11:33 AM   #6 (permalink)
EGrier's Avatar
Default
The arm tip is white on the GFS arm. The stock CV 50s tip is aged white. So they are not an exact match. You might be able to fit a replacement tip on the GFS arm or buy any other 10/32 screw thread arm that has the color tip you want. GFS has their #D51 arm with a cream tip that will fit. I don't know if the cream tip is an exact match to the stock CV 50s color, but it will be closer than stark white. (I just took a look at the GFS website. It shows the D51 trem arm's availability as "Not for Sale" at the moment. I'm not sure if that is the same as "Out of Stock" of if that means something different.)
Ok cool.
Thanks for the information.
Old 08-16-2010, 10:03 PM   #7 (permalink)
motoman45's Avatar
Default
double on gettin the whole trem...
Pic Whore....
motoman45 is offline   Reply With Quote
Old 08-19-2010, 05:14 PM   #8 (permalink)
Default
I put mine in last night, after setting it up and intonation, I feel it is a great upgrade!
Reply
Bookmarks
Search this Thread:
Advanced Search
BB code is On
Smilies are On
[IMG] code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Similar Threads
KGC Brass Block finally arrived. dannyvawn Squier Stratocasters 6 11-11-2011 06:17 PM
Update/ 2 point tremolo block dannyvawn Squier Stratocasters 23 08-02-2011 12:36 PM
Bridge block wood ? 5thumbs Squier Stratocasters 3 07-05-2010 09:15 PM
New update/ Found a manufacturer for the block dannyvawn Squier Stratocasters 15 06-25-2010 12:26 PM
Squier Stratocaster SE KRamone27 Squier Stratocasters 19 03-08-2010 01:12 PM
» Random Photos
Some O my Squiers
eyerish
Some O my Squiers
» Recent Threads
Title, Username, & Date
Go to first new post NGD! Lake Placid Blue...
bugo
Today 12:34 AM
Go to first new post i found a different way...
telegal55
Today 12:53 AM
Go to first new post There's many like it,...
Deadcenter
Yesterday 12:15 AM
Pickguard help for tele...
telecastro
Yesterday 11:06 PM
hello from USA
bwillis69
02-02-2012 08:19 AM
Hello from Northern CA
broomhandle
02-09-2012 08:42 PM
Easiest upgrade for...
squierjosh
Yesterday 11:10 PM
Caps for Lil Puncher...
squierjosh
Yesterday 07:50 PM
NGD - surf / surf
JapaneseBullets
02-08-2012 02:05 PM
Busted out the SX Tele...
horax
Yesterday 07:55 PM
» Sponsored Links
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
© 2009 All rights reserved.
